Question about Toshiba Office Equipment & Supplies
How can i fix the error code C970 on my toshiba e-studio 5520e
6ya staff
SOURCE:
didi2005
  • 727 Answers
SOURCE: toshiba e studio 350
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
Posted on May 25, 2009
tonesmaker
A.Hadi
  • 60 Answers
SOURCE: Error code C970 on my
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
Posted on Jun 12, 2011
Alex Patrascu
SOURCE: ERROR C970 TOSHIBA E STUDIO 350
[C970] High-voltage transformer abnormality
(1) Is the main charger installed securely?
(2) Check if the spring of high-voltage supply contact point is deformed.
(3) Check if the charger wire is broken or the main charger grid is deformed.
(4) Check if any foreign matters are on the charger wire or main charger grid.
(5) Is the transfer/separation charger installed securely?
(6) Check if the transfer/separation charger wire is broken or unhooked.
(7) Check if any foreign matter is on the transfer/separation charger wire.
Posted on Oct 02, 2012
SOURCE: toshiba e-studio 232 code C970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check the black color plastic piece mounted on the machine frame where the main charger connects. If this part is damaged, the high voltage will arc through which can cause C970. (found in several machines).
Posted on Nov 28, 2012
SOURCE: How can i fix the
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Posted on Dec 04, 2012
Toshiba e studio 283 error c970
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20283&code=C970
C970
Description
Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
Causes
Remedy
1. Is the main charger installed securely? 2. Check if the spring of high-voltage supply contact point is deformed. 3. Check if the needle electrode is broken or the main charger grid is deformed. 4. Check if any foreign matters is on the needle electrode or the main charger grid. 5. Check if the transfer roller and the separation needle are installed securely. 6. Check if the transfer roller or the separation needle is removed. 7. Check if there is any foreign matter attached on the transfer roller or the separation needle. Toshiba Studio 283 Error Codes
Apr 06, 2018 | Toshiba Office Equipment & Supplies
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
Error c970
Apr 22, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
there is no reset code for c970 ...the cause of this is the second transfer roller grounding contact..check if there is foreign materials on the contact ...this error is grounding contact problem
Error code C970 on my toshiba e-studio 2500c. Sais call for maintanance...Can I clear this or fix this on my own?
Jun 08, 2011 | Toshiba e-Studio 350 Copier
How can i fix the error code C970 on my toshiba e-studio 230?
Nov 01, 2010 | Toshiba e-Studio 350 Copier
Had a power outage, not a surge, now reads call for service.
Press "clear" and "8" simultaneously and hold, this should display the error code...what is the error code?
Jun 14, 2009 | Office Equipment & Supplies
Toshiba e studio 350 has a c970 code
May 22, 2009 | Toshiba e-Studio 350 Copier
Toshiba e-studio 232 code C970
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
