Try inserting the windows recovery disc and reboot the machine. At the language screen, bottom left, click repair your computer. At the recovery options screen, click on startup repair. This should recover the boot manager file. Reboot machine when completed.
Only if the machine was upgraded to USB. Then, a new version of disk manager came with the upgrade kit that your dealer installed.Otherwise, it comes with any of the 5D Embroidery packages that are currently available.
you need to install sound driver
go to device manager
at device manager there are yellow mark (?) or (!)
insert your motherboard cd driver
and install sound driver
the other way is at device manager right click at yellow mark and chose update drive, then follow instruction until finish and the yellow mark at device manager disappear
Disk Manager is part of Customizing software, in case you were wondering if you needed to buy more software. Ask again if you are having trouble locating it. You also need to format your floppy disk in Disk Manager before writing your designs to it.
This may be a simple driver glitch with the modem. Uninstall the modem drivers from the device manager and reboot. The machine will find the modem and reinstall the drivers. If this doesn't work, then check for driver updates or any utility drivers from the support site for E-machines.
Disable Machine Debug Manager (MDM.EXE) using MSCONFIG, under the Startup tab. Also, in Control Panel / Internet Properties, on the "Advanced" tab, there's a check box for "Disable Script Debugging". If that's not checked, it could still start the Machine Debug Manager even after you have unchecked it from MSCONFIG. . For more information, please visit http://support.microsoft.com/support/kb/articles/Q221/4/38.ASP
Press Copier management button and You can see what is wrong in management settings.probably You reached some limitations adjusted in management mode.Default pasword for copier management is 2500.
If you dont know what to do, switch off copier management.
