SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it
run for a minute or two, then stop the cycle, open the lid and slowly
add the gallon of hot tap water. Don't overfill — you just want to
raise the water level so that it is able to reach and clean the inside
top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle.
In a couple of minutes, stop it again and just let it sit for at least
30 minutes. Afterward, let the cycle finish, and open the lid to air
out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
