As Tom has answered........ Manual will allow you to manually change the date and time and Auto will automatically set the date and time from your wifi connection.
The Manual option should allow you to set time manually.
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
SOURCE: Change Date/Time on Canon Fax L350
Left the flap on the right hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
SOURCE: changing date and time for panafax uf6000
press function-7-1-start- change the time and date on the machine. then hit start then stop
SOURCE: Changing the time on my Motorola Razr V3 phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
SOURCE: Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
