SOURCE: needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
SOURCE: sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
SOURCE: needle keeps hitting the pressure foot and breaking
your machine probably needs to be retimed.
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
SOURCE: Needle keeps catching the embroidery foot and breaking
Happened to me to All I did was to press the embroidary foot a little backwards and check if the little arm that rest on the shaft that goes up and down is seating correclty.
