SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
Short Bolts:
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
SOURCE: head bolt torque for a 1996 ford ranger 2.3liter
it is in the haynes repair manuel and chad is right
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
SOURCE: HEAD TORQUE AND SPECS FOR A 2001 HONDA ACCORD 2.3L
Tighten the cylinder head bolts. Tighten the cylinder head bolts is sequence to 29 Nm (3.0 kgf-m, 22 ft. lbs.). Use a beam-type torque wrench. When using a preset type torque wrench, be sure to tighten slowly and do not overtighten. If a bolt makes any noise while you are torquing it, loosen the bolt and retighten it. Make sure the threads are clean, new heads bolts are best.
