Brian Miles Posted on Jun 08, 2019
What size fuse does a Paradigm dsp-3100 take ??
Jimmy Barnett
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 09, 2019
Jimmy Barnett
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
Helped
6932
Points
63
100-240v 1.6amp is what it says.
My Paradigm PDR-10 subwoofer needs a new fuse (1.5amp 250v) but I cant find the physical location of the fuse on the sub anywhere. Ive looked at it for a long time now. Any help? Thanks, Bryan Tal
Try right behind the power panel. Certain models you have to remove amplifier back panel. Then some are soldered on and some are encased in some kind of holder usually by the power input. Be carefull of electric shock. Make sure device is un-plugged while powered on to help with discharging internal capacitors if possible or drain caps with appropriate resistor to drain them safely if possible.
My paradigm ps1000 speaker does not turn on what's wrong ?
Check all fuses and plugs, if they are OK your power supply may have failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
3helpful
Our ten year old paradigm ps 1200 subwoofer does not power up, although it is plugged in and properly connected to the receiver. Why is this? Is it a lost cause?
Disconnect the power, pull the amplifier out by undoing the screws that hold it in.
When you pull it out, look closely towards the top there is a little 1.8A fuse. It probably has blown.
Replace that and you should be back in business.
Paradigm 5.1 to 7.1 system
The Dolby curcuit in the Paradigm must be Dolby 7.1 or it will simply not be able to send the extra channel signals to the speakers. In otherwords you will not get the full 7.1 sound from two speakers added to a 5.1 amp.
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
1helpful
Can't find owners manual for paradigm cc-300 center channel
http://www.retrevo.com/s/Paradigm-CC-Speakers-review-manual/id/13247ci865/t/1-2/
Lightning struck and my paradigm ps1000 doesn't work anymore.
Paradigm service is excellent and they can supply parts. The amplifier has a one year warr. Check with a dealer or www.paradigm.com Your insurance may cover it.
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
