Question about Nokia Computers & Internet
My nokia 3 is stuck in fastboot mode. How do i unstuck the phone?
I tried to reboot, switch off. i cant remove the batery
  • Crisp Shehi
    Crisp Shehi Jun 08, 2019
    Hold vol+ and vol- for 30secs. It'll reboot in normal mode.
    New Friend:
  • 63 Answers
Press vol- (down) for 30 seconds.
Posted on Jun 08, 2019
  • Crisp Shehi
    Press vol- and vol+ for 30 seconds.
6ya staff
SOURCE:
Anonymous
SOURCE: power on/off problem
3230 try another battery
Posted on Dec 19, 2007
Anonymous
  • 70 Answers
format ur phone by using code * + 3 + Call key + On/Off key till formatting appears, if this does not work u have to flash ur phone
Posted on Jan 13, 2008
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: I think I might have bricked my phone
you should take the phone and have the firmware reflash by a professional service center tech.
Posted on Aug 31, 2008
fossildude
Dennis Jambalos
  • 832 Answers
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Posted on Jun 15, 2009
Anonymous
SOURCE: Phone stuck in Test Mode
my did that when i plugged the charger in while the phone was off. i yanked the battery, went to the bathroom, came back and put the battery back in, and i was good.
Posted on Dec 25, 2009
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
Vtouch v705 is locked how I can reset the password
I read an article on how to reset the Vtouch V705 and although I have not performed this operation my self, you may want to investigate the following and see if it something you can work with that may help solve your issue. If this does not work or apply please reply and I will continue to look for possible solutions to solve your problem. Here is the quote on what you might try (if this applies) to possibly solve your issue.
"works well on chines android tablets! 1.Download the android tool. https://www.mediafire.com/?7se8s62sj1y5fpo2.extract and save to any location on computer2.open extracted folder and open software use the appropriate number for whatever job you would like to do.number 4 to reset Gmail lock, pattern lock, or password.when device reboots you may need to restart it a second time that's it all done. subscribe, like, share, comment.User Manual for Android Multi Tools v1.02bfirst device must install correct driver This program works with any Android device .Requires root and enable Debug mode or fast boot mode.choice 1-6,S,H can work with Debug Mode only.choice 7-9 can work with Fastboot Mode only.choice detail1.Check Device for check connection of device to PC.2.Reset Face/PIN Lock for reset face lock on android 4.1.x and PIN lock without lost data.3.Reset Face/Gesture Lock for reset face lock on android 4.1.x and Gesture lock without lost data. After device reboot Then you can draw anything for unlock.don't forget close lock in security menu4.Reset GMail for reset gmail login after try many time wrong unlock 5.Wipe Data for reset all data to factory setting.6.Reboot for reboot device to normal mode or exit from adb shell.7.Check Device On Fastboot Mode for check connection of device to on FastBoot mode.8.Wipe Data / Cache On Fastboot Mode for erase user datat and cache on Fastboot Mode to resolve freeze,stuk on boot logo or slow down device. That is often found in the CPU Spreadtrum SC6280/SC8810.9.Exit Fastboot Mode for reboot your PC or exit FastBoot.0.Go To Command Promt for entering DOS promt.you can use command in this soft folder And can return to the main program by type exitS.Software Info for info CPU inside,firmware version and etc.H.Hardware Info for determine the IC number of Gsensor,touch screen,Camera,WIFI and moreR.Report / Contact Me links to the specific problems of the Phase I program and a bookmark.D.Driver Download for loading the drivers in case you do not have the driver installed in your PC - See more at: http://celularmovil.info/video/view?videocode=okEyk5LrNDc&startpage=6#sthash.j9wiRuoL.dpuf
Please let me know if this works out or if you have any additional comments or questions. Like I said before I have not actually used this method myself so PLEASE be cautious when downloading and installing any type of software. Thank You!!
Nov 20, 2014 | Computers & Internet
How to reset my lenovo A269i ?
Hi Anonymous
I trust you are well
This process will remove everything from your phone and reset it to default settings as when you first received the phone including all contacts, apps etc.
1. Turn off your device. Make sure it`s battery above 50%.
2. Now press and hold Power and Volume Up(+) together.
3. It will display Recovery Mode, Fastboot Mode and Normal Mode options.
4. Now select Recovery Mode option using volume keys, android logo will appear.
5. Now press the power button one time it will display the options.
6. Select wipe user data option using volume up button.
reboot your mobile.
Hop this helps
Kind regards
Aug 20, 2014 | Cell Phones
How do i factory reset my zte concord v768?
Just try with the below steps to hardreset your phone:-
1.Switch off the handset, and press the power-key and volume-down key at the same time until get recovery mode;
2.Press home key get into next interface;
3.There will be four choices:reboot system now;apply update from sdcard;wipe data/factory reset;wipe cache partition;
4.Use "Vol+" and "Vol-" to move the cursor up and down;
5.Move cursor to "wipe data/factory reset," press "menu" key to select it.
6.Then use vol- key to move the cursor to " yes-delete all user data" , press menu key to select it.
7.Then choose reboot system now ,you phone will reboot itself.
Mar 24, 2013 | ZTE Cell Phones
I have Vodafone Nokia E65. Its now stuck at the start up and its not rebooting. It just says at the start NOKIA, and not going further towards rebooting. I tried that green button, star and 3, but that is...
your phone needed to be reprogram, bring it to a cellphone technician who has a tools or gadget for reprogramming cellphones that support your phone.
Jun 30, 2011 | Nokia e65 Cellular Phone
My n73 hang i cant use my phone if i replace batery hang again
Formating may solve this.
*You will lost contacts and files on phone, if you do this*
turn off the phone, press 3,*,call(green one) at a time and power on holding the keys ( it means finally 4 keys at a time, dnt laugh , it is way, phone can he hard formatted)
Try untill it askes for the time and country. Pressing 4 keys at a time is a bit tricky so, it is easy to miss one/two attempts, atleast i do.
Oct 09, 2009 | Nokia N73 Cellular Phone
How can i remove standby mode of Nokia N95 8 gb
hi,
please try to delete some of the files present in the phone memory and restart your phone,,,,,if the problem presists then try reset your phone *#7780# reset to factory settings.....if the problem presists do this
C.O.D.E 1: --->>*#7370# or
C.O.D.E 2: --->>
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button, press-> 3, press-> *,
STEP: 3. Now Switch on your Mobile.
thank you,remember to vote
vijayananth
Sep 22, 2009 | Nokia N95 Cellular Phone
Nokia 1100 test mode
REMOVE BATERY FIRST AND IF U CAN POWER ON SO FOLLOW THE INSTRUCTIONS:
TYPE : *#7780# and it will restart and after restarting put again
*#7370#
If this could not be helpfull just fllash it!
OPS...If u do that all information will be deltet sir(phone nr.messages etc..)
Oct 30, 2007 | Nokia 1100
Computers & Internet Logo
48 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
