Question about Maytag Dryers
Maytag Neptune dryer model MDG9700 does not heat up. When dryer is on, I can feel very light heat and there is a slight burning odor. Drum spins and dryer appears to work as usual.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Have you checked the flame sensor? There is a safety flame sensor monitoring that there the unit is keeping a burning flame or the gas valve shuts off. Most lack of heat in dryers is caused by a bad igniter coil or a bad flame sensor. And the last answer. Check both. Igniter coil can be checked with a meter or carefully powered momentarily on a workbench. Fire hazard - don’t leave it turned on.
Posted on Aug 12, 2019
  • 141 Answers
Check you flame. If the flame is very short (less than half way down the burner tube, it can be a gas pressure regulator failure. They are adjustable but that usually indicated it is about to fail. Make sure the flame ignites every time you hear the relay and solenoid valve click. The is a small panel on the front that can be removed to see the burner and the pressure regulator. The is a glow igniter that comes on several seconds before the gas is admitted. Confirm that works. Check at the dryer vent whether you smell gas once and a while which would be an indication of a failure to ignite.
Posted on Aug 09, 2019
6ya staff
SOURCE:
Anonymous
  • 146 Answers
SOURCE: change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Posted on Dec 22, 2007
Anonymous
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Maytag Dryer model # LDE313
at the bottom of the front panel you have two screws, remove those and swing out at bottom and drop off
Posted on Feb 06, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
Anonymous
  • 230 Answers
SOURCE: dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Posted on Nov 16, 2009
Gas smell from inside drum
This is caused 95% of the time by a bad igniter, it does not light it constantly and will give this odor.
The igniter light the gas to burn and heat, also make sure that the exhaust going to the outside is not kink or clogged at all this will also cause this problem.
Here is the igniter to order.
Nov 30, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer will not spin when turned on. Drum spins by hand. Makes a buzzing noise and elecrtical (burning) smell. Dryer is unplugged now and vent is clear.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer is no longer heating up.
start with checking that the dryer has 220volts to it. You can have a 2 legged circuit breaker half tripped, which will allow the light to come on and the drum to spin, but no heat. Next you should check the element for continuity. If that isnt the cause, then it most likely will be a thermal cutoff. If you go to sears parts direct, you can put in your model # and get a complete breakdown, with part #s and all.
Oct 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Neptune has just started new odor
The rubber belt from the engine to the drum is loose: replace it, it's worn out.
Nov 16, 2009 | Televison & Video
Maytag mdg9700 neptune, likely coil problem
Are you talking about the heating element? We have them available. Please call or email us and we will send them to you right away! We hope to hear from you soon! Thanks. Ella
Aug 26, 2009 | Maytag Neptune MDG9700A Gas Dryer
Neptune Dryer Just Stopped
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Apr 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Dryers Logo
102 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
