SOURCE: need code for rca universal
I found this site:
http://www.insignia-products.com/universalcontrolcodes.aspx
which lists the universal remote RCA (model RCU807) code as 135
I just bought one of these TV's last night.
Good luck.
SOURCE: advent 27 inch flat screen
i have model dv2020a television and it is locked. i cant unlock my television. i don't have the remote i have a universal remote can u help me.
SOURCE: the rca tv will not power up 55 inch
Is it a rear projection set? or LCD? If it is a projection set it could be a bad High voltage splitter. Part is about $30 If it is LCD it could be a bad power supply or inverter board. A good tech can replace capacitors in power supply without replacing the board
SOURCE: 42 INCH SVA FLAT SCREEN WONT WORK WITH UNIVERSAL REMOTE
Have found that this $45 remote from this site works: http://shopsva.com/svauunreco.html
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
