SOURCE: What is the airgap for the magneto on a stihl fs36
normally .16 or a match book cover between the two would work.
Testimonial: "was that supposed to be .016" instead of .16 Thanks!"
SOURCE: my stihl fs36 Whippersnipper continues to flood what is the cause
Your float adjustment in the carb needs to be reset, or there is trash under in inlet valve in the carb.
If the float is set wrong or trash in the inlet valve then that will cause the problem of flooding,
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
needs a carb kit with needle valve $20 at a small engine store
SOURCE: Stihl FS 36 trimmer doesn't have power, won't rotate.
Hi, remove the wire screen from the muffler outlet, regards Phil.
SOURCE: I need to see a fuel line diagram for Stihl fs36 trimmer
Hi Lee Milleer
I hope this is what your looking for
Please take time to rate me
Bud
