THE REMOTE TURNS THE TV ON AND OFF BUT DOES NOT RESPOND TO ANY OTHER BUTTON... OTHER INFO THE INDICATOR LIGHT IS PULSING RED
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
SOURCE: Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
SOURCE: Element LCD tv model: FLX-3210
I just checked and my tv was purchased with a credit card that gave a double warranty. I have to fill out some things but it should be fixed eventually...
SOURCE: TV doesn't turn on - red lindicator light is just flashing
check and replace your horizontal output transistor as well as the regulator..
