Televison & Video Logo
S
SIidney Temba Posted on Jun 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sansui 32inch HDR Ledtv model sty0632 is audible, sound is fine but no vision; upon careful observation the picture is too dark for human eyes to see. Whatsup doc? Sidney.
Franco Dosil
Level 3:
Top Expert:
  • Sansui Master 10,542 Answers
  • Posted on Jun 22, 2019
Franco Dosil
Sansui Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377322
Points
178965
Hello Sidney, so you comment, your Sansui would have problems in the back lighting of the LCD panel (BackLight)
Usually one or more LEDs are burned, this causes the lighting system and the TV to be interrupted, it keeps the screen dark and with sound
You should replace all the LEDs, to ensure a repair that lasts longer, because if you only replace the burns,
at any time another of the originals is burned and you have to do the work again, with the risk of breaking the LCD panel
I hope you can solve the problem, comment the results
Greetings Franco Dosil
Hola Sidney, por lo que comentas, tu Sansui tendr?a problemas en la iluminaci?n trasera del panel LCD (BackLight)
Por lo general se queman uno o mas Leds, esto hace que se interrumpa el sistema de iluminaci?n y el TV, se queda con la pantalla oscura y con sonido
Deber?as reemplazar la totalidad de los Led, para asegurar un reparaci?n que dure mas tiempo, porque si solo reemplazas los quemados,
en cualquier momento se quema otro de los originales y tienes que hacer el trabajo nuevamente, con el riesgo de romper el panel LCD
Espero puedas resolver el problema, comenta los resultados
Saludos Franco Dosil
3 Related Answers
Anonymous
  • Posted on May 15, 2009
SOURCE: TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
Anonymous
  • 3 Answers
  • Posted on Dec 12, 2009
SOURCE: Red light upon startup.
possibly 5w ceramic resistor in the psu start up stage
gopakumarg43
  • 76851 Answers
  • Posted on Apr 01, 2016
SOURCE: Sansui led sty0632 has no picture or sound and horizontal line on the right
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site...
2answers
Service code for 32inch sansui led tv sled hdr
Sansui model - LCD TV s 3281Yw-M I need sarvice mode code plz tell
How does nifedical effect the human eye
Nifedical, or Nifedipine, is used to treat high blood pressure and angina.
Side effects may RARELY include
- bloodshot eyes
- bluish vision
- blurred vision
- other changes in vision
If the person taking Nifedical notices these, he or she should go back to the doctor.
I have a sansui 32inch hd led tv sty0632-s that just stays switching on and off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Bunker hill security color camera model 95914 suppose to have night vision, has the led lights that circle around the lens. Should those lights be red or at least light up for night vision? I can't see...
If the LEDS are truly for night vision only, then they are most likely Infra-Red types, invisible to the human eye, but visible to camera sensor. A way to test if they are IR and working is to point another digital camera directly at the front of the security camera at night.
The cell phone or webcam sensor will see IR LED's as white spots.
As for this model coming with night vision, I don't know.
There is not picture its just vioce
Battery OK, IR light up, no green image on the intensifier image tube, correct! What type of voices are you hearing? Give ATN Aries 390 two Zolof and wait two day, just kidding!!! The noise is a crackling, high freqencey hum, popping, etc. Also remove the eye lens, it screw off, then remove the scope to someplace where it semi dark. Turn it on and observe the 18mm white plate and see if it turn green---no green---no look see---no image intensifier tube, it dead that is the mage tube. stewbison.
WHY DO I GET RED EYE IN MY PICTURES WITH RED EYE ON
It's becasue of human eye. Eye bottom is red, and when flash fires, camera captures eye bottom
Red eyes function makes pre flash, for pupil to become smaller, but if it is very dark, it is not enought. There is no best solution for eyes not be be red, but shooting techniques can help You or You can try some software after.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
