Garden Logo
Jeff McMichael Posted on Jun 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Toro TimeMaster mower. It will start but will not stay running. Could a bad kill switch cause this?
I have replaced the spark plug, fuel filter, and fuel lines. I have also cleaned the carburetor. I have spark and seem to be getting at least enough fuel to start the engine but it will not stay running
Tito Marquez
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jun 12, 2019
Tito Marquez
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
2061
Points
If you spray staring fluid into the intake and it stays running you have a bad carburetor
john h
Level 3:
Top Expert:
  • Toro Master 29,494 Answers
john h
Toro Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7546907
Points
193449
Reclean rebuild or replace the carb
  • 2 more comments
  • Jeff McMichael
    Jeff McMichael Jun 12, 2019
    Can you people not read
  • john h Jun 12, 2019
    yeah we can read and 95% of people think spraying carb cleaner is cleaning their carb and the limited symptoms you have given point to fuel delivery if off kill or safety switch failed wouldnt start at all so read an instruction sheet for rebuilding or replacing carb
  • Jeff McMichael
    You obviously can't read cause I asked a yes or no question
  • Dennis Jun 13, 2019
    The kill switch can't be the problem.
    If it does slowly, its fuel related. (Clogged cap vent most likely cause if it runs ok for several minutes.)
    If it dies abruptly, its electrical related. Most likely cause is coil that opens when it gets hot.
Derek
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jun 11, 2019
Derek
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
5729
Points
49
Take out the float and sit it in a container of fuel for 10 minutes and if it floats it's ok but if it sinks that's the problem
durantheman
Level 2:
Habit-Forming:
  • Expert 148 Answers
durantheman
Expert
Level 2:
Habit-Forming:
Answers
148
Questions
Helped
40424
Points
441
Did you clean the float bowl, it collects dirt and stops fuel to the needle valve
  • Jeff McMichael
    Jeff McMichael Jun 11, 2019
    Did you not read the part where I cleaned the carb
  • durantheman Jun 12, 2019
    Some people just spray carb cleaner in the intake
2 Related Answers
Anonymous
  • 195 Answers
  • Posted on Mar 30, 2009
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 08, 2009
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
52 toro Z Master 2000 series won't start
There could be a few different reasons why your Toro Z Master 2000 series lawn mower won't start. Here are some things to check:
  1. Fuel: Make sure that the gas tank is full and that the fuel is fresh. If the fuel is stale or contaminated, it may not be able to properly power the engine.
  2. Spark plug: Check the spark plug to make sure it is clean and in good condition. A dirty or faulty spark plug can prevent the engine from starting.
  3. Air filter: A dirty air filter can restrict the flow of air to the engine, causing it to run poorly or not start at all. Check the air filter and clean or replace it if necessary.
  4. Battery: If the battery is dead or not fully charged, the engine may not start. Charge the battery or replace it if necessary.
  5. Ignition switch: Make sure the ignition switch is in the "on" position and that the safety switch is engaged.
If you have checked all of these things and the lawn mower still won't start, it may be a more serious issue that requires professional repair.
Dec 13, 2022 • Toro Garden
My Toro TimeMaster 30 in. Self Propelled Mower with Briggs & Stratton Engine hasn't been started in 3 months and won't start. Mr Need Help
Raymond. clean the spark plug and be sure the gap is .030 check to see if it has spark. if so pour a little gas in the carburetor, if it starts for a few seconds and dies. you have a fuel problem. be sure the fuel lines are good as well as fuel filter if equipped. you may even have to take the carburetor off and clean it real good.
Nov 16, 2016 • Toro Garden
Model 20199 used once and will not restart.
Did you take the spark plug out and touch it to a bolt head while pulling the cord? if you did you should see a small spark jump between the plug center electrode and the ground electrode. if you do not see a spark you either have a short in the plug wire or the coil is faulty.
2answers
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Toro self-propelled mower will not start. I thik it is the kill switch. What can I do now? Can I bypass?
Yes you can just unhook the wire and see if you have spark then, only thing is if it is the kill switch then you will have to replace it or you won't be able to shut your mower off unless you choke it but that will eventually wash the oil from cylinder causing premature cylinder wear, hope this helps you
Stalled out does not seem to get spark
First, you must find out if your getting spark or not. Remove plug, and ground it to the motor and pull cord, see if your getting spark. If you are, then your problem is your not getting fuel. If your not getting spark there are a couple of things that can cause this. !st, defective spark plug, Second, cable from control handle to engine may have stretched and is not releasing the kill switch. Disconnect the kill switch wire and check to see if you have spark, if you have spark, replace engine control cable. If with kill switch wire disconnected you still have no spark, you would have a defective magnito coil, which is rare, but does happen. This engine control cable kills the spark when you release the handle and also is the engine brake, It serves two functions.
Toro mower recycler 22 inch will not start has spark to plug and gas is new and pull assembly is good
Is the plug actually sparking? To test this, first, unscrew the plug from the engine...then, with the wire attached to the plug, and with it laying on the deck, pull the engine over with the rope starter. If it doesn't spark, the plug needs to be replaced. The other possibility is that the kill switch is bad.
Dec 12, 2009 • Garden
Toro super recycler mower will not stay running, has fuel and oil and air filter was just replaced
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
HTH
Good Day.
2helpful
10 yr old mower, has not been started for 3 or 4 yrs, won't start
Remove the fuel filter and fuel line and replace then try it, if it still does not stay running you will have to change outthe primer bulb. If you need more innformation let me know. Aslo please rate this as this is a free service and thanks for using Fixya.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
