The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Otherwise it would never stop freezing. Let me know what you find out.
Hi - Generally speaking, the temperature control in a Frigidaire upright freezer is located directly behind the temperature control knob. Make sure the unit is turned off completely and the evaporator cover and gasket will need to be unscrewed to get directly to it. Before repairing or replacing any parts of your appliance, might want to consider contacting a professional to move forward accurately due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out be the root cause of your initial problem. I suggest this in the event that if the unit has a limited warranty and if you continue it will cause the warranty to be voided.
