SOURCE: my singer magic press 4 iron comes on but the plate will not heat
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
SOURCE: My watch strap pulled off the watch while
Go to their web site "Casio.co.nz", click on "support"and then choose "service agents".
You will then be presented with a map from which you can find your nearest service agent.
SOURCE: Trying to get on xbox live all details in but it
unlock and fix xbox 360 yourself within 1 hour
try http://3redlight.tk
