When I hit s & 0 its write (''''''') Please give me its solution..
SOURCE: We have an IBM 6747 electronic typewriter. When
On the rear of the print solenoid plunger is a plastic cap either white or yellow it is probably broken. They are available but a little tricky to install.
SOURCE: We have an IBM 6747 typewriter electric typewriter
Either the print solenoid is gummy or the plastic cap on the plunger is broken. They are available but a little tricky to install.
Yes it is worth fixing.
DickyO
SOURCE: My IBM Selectric System 2000 Wheelwriter
The plastic cap on the print solenoid is probably broken. We sell them with installation instructions for 20.00 including shipping. DickyO Cleveland Business Machines 216-241-0027
SOURCE: print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
