SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
SOURCE: LG Front Load Washer
I've had trouble with my LG WM016CW front load washer leaking from the start. After many service calls, a Sears tech finally figured out that the water was running out the air vent on the back of the washer(leaks out even when no soap is added, so it's not a soap issue). The Sears tech called LG and it turns out that there should be mushroom valve(not on the original parts list) installed between the tub and air vent hose to prevent water from leaking through the air vent. That seems logical, so why wasn't the valve installed to begin with? LG is obviously aware of the problem, so why haven't they had the courtesy to inform their authorized techs? No, instead they wait for some poor tech to call them, then give out a part number that has proven to be dfficult or maybe even impossible to get(been 2 weeks and still no part). I believe LG is trying to hide the fact that the valve was left out of the original washer design and they do not want to go to the expense of correcting their mistake. Wish I could just return the washer, who wants one that leaks?
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and
removal:
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.This fault indicated can be due to failure of the water level sensors causing overflow but in all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
