Boating Logo
Adam Roberts Posted on Jun 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil ratio for a DT65 Suzuki outboard motor - Suzuki Boating
Michelle Voyles
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Jun 16, 2019
Michelle Voyles
Expert
Level 2:
New Friend:
Answers
42
Questions
Helped
3760
Points
125
50:1 ratio for the Suzuki outboard motor
1 Related Answer
Anonymous
  • 91 Answers
  • Posted on Jun 20, 2010
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Suzuki dt65 Model 6501104195 @ Any idea on the year model?
The serial number relates to either DT65ESX or DT65ELX and the year of manufacture is 1981
1helpful
2answers
1957 johnson outboard 10 hp fuel mixture ratio
https://www.google.com/search?q=1957+johnson+outboard+10+hp+fuel+oil+ratio
What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
Feb. 22, 2021
What is the mixing ratio for a Johnson outboard motor? - Mvorganizing.org
1helpful
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
1helpful
2answers
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
HAVE TO REPLACE A CDI UNIT NEED A BREAKDOWN DT65 SUZUKI 6501
Suzuki DT65 1978 Wiring Diagram Page: 1 - iboats Boating Forums ...
forums.iboats.com/...suzuki.../296297-suzuki-dt65-1978-wiring-diagram Jan 5, 2009 - 6 posts - ‎4 authors ... diagram for a Suzuki DT65 6501 D-10978 (assume this is 1978). ... I looked around for a shop service manual on the internet, located a ...
Flashing light oil
NO THE OIL IS OK , THERE IS NO FLASHING LIGHTS
I just bought a suzuki outboard dt65 it sat for 6 years what do i need to do for water ready
remove carbs and clean jets etc ! clean or replace fuel tank and check primer bulb and line not perished ! check compressions and sparks ! remove gearbox and replace the impellor even if it looks ok and replace the gear oil ! run in tub of water for an hour to check cooling and the thermo opening also check no fuel leaks etc !
5helpful
Oil fuel mix for a 8 hp suzuki out board
If your looking for the premix ratio for this it is 50:1
Please take a moment to rate my answer............Thanks
1helpful
Suzuki outboard motor 65 hp --oil sensor keeps
Jun 19, 2010 • Boating
2answers
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 • Boating
Top Suzuki Boating Experts
jws1013
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
