Question about LG Televison & Video
Tv Problem. LG 65UF6450-UA When powered on, LG logo appeared like normal. Screen went black. Nothing happened. Unplugged and let sit overnight. Powered back on and black screen. No sound. No backlight. Did “flashlight” test , pressing menu , only can see some static and different shades of grey no words and no menu. Tv made in 2015. I will be removing the back to check for blown capacitors or burnt circuit board. Is there anything else I should be looking for and testing. I have a multi meter and am pretty proficient with electrical.
    Top Expert:
  • LG Master
  • 10,535 Answers
Hello Roe, for what you are commenting, it would seem a feeding problem, which can be either on the Food Source plate or on the Main plate, where the sub-sources are located
I send you the link of the service manual, control the voltages, remember to download the high voltage capacitor of the primary stage of the source
I hope you can solve the problem
Greetings Franco Dosil
Hola Roe, por lo que comentas, pareceria un problema de alimentacion, que tanto pueden estar en la placa de Fuente de Alimentacion o en la placa Principal, donde se encuentran las subfuentes
Te envio el link del manual de servicio, controla las tensiones, recuerda descargar el capacitor de alta tension de la etapa primaria de la fuente
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.electronica-pt.com/esquema/func-download/33245/chk,da20a5b273d3354edf2a181680ef2b3f/no_html,1 https://www.lg.com/us/support/product-help/CT10000018-1430510575535-firmware-or-software-update
Posted on Jun 17, 2019
Anonymous
SOURCE:
paulbtorrent
paulbtorrent
  • 34 Answers
SOURCE: I have an Envision H170L monitor that goes dark
http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
take your plate a part, without desolding anything, reconnect your ccfl's to your invertor , this is how I found that with only 3/4 my monitor ccfl backlights worked. Monitor had classic for 2 seconds and I coud see a windows shadow (I changed my capacitors).my was a kit assembly plate and disassembly easy, light clips and small screws, gentle, movements, set your work bench very clear, tube break, push from the sides where they plugged together always!
I guess from this that the inverter self test check all the ccfl's!
hence the on / check/ off screen (the high power bit, leaving the lower power bit on)
Posted on Feb 08, 2010
andrewalco
SOURCE: I have a Samsung ln32c450e
tv wont come out of sleep mode
Posted on Jan 05, 2011
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: I have a Soyo mtsytpt3227ab
It seems back light inverter board is defective in said symptoms because you get sound in tv but no picture. Please point strong flash light at tv screen to observe faint image, if image is there then replace back light inverter board that is available with shopjimmy.com
And if no faint image found then power supply board would be defective and it is available with shopjimmy.com
Hope these info will help.
Thanks.
Posted on Mar 14, 2011
TODDAS
Todd Hill
  • 433 Answers
SOURCE: I have a 32" AOC Envision L32w761 LCD hdtv with no
need to ck for your 24 volts going to your inverter board if missing ck power supply
Posted on Oct 07, 2011
Cant turn tv on
may be your DM board is gone......
Mar 08, 2008 | LG RU-23LG10P 23 in. TV/DVD Combo
Hi I have a lg smart tv model # 65UF6450-UA when I turn it on the red light blinks three times but there's no picture or sound . Do I need a new driver board?
smart tv's have their own built in computer and as with any computer they can get confused and don't know what to do.a simple thing to try is unplug your tv completely from power source including a power strip. hold the power button down for at least 60 seconds plug it back in see what happens. don't cost anything to try this.
Apr 30, 2017 | LG Televison & Video
How to repair LG LCD TV 47LG70-UA no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 12, 2016 | LG Televison & Video
My LG LED tv model 32LN530B-UA built in March/13 suddenly has no picture. What I have now is a black and white snowy back round with an overlay of fluctuating coloured horizontal lines with short vert
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | LG Televison & Video
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
LG 22" LCD Screen went white
same things happened to me...did you solve this?
Jun 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Keeps blowing up
Sounds like a factory issue. You should call lG directly and explain it to them. They're likely to get you another unit.
Geno
Mar 10, 2008 | LG 50PX4D 50 in. Plasma Television
Televison & Video Logo
680 people viewed this question
Ekse
RONALD CARTER JR
