Hello TANAY, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola TANAY, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: pls send me sansui model-s2s21,21"ctv
i had sansui s2s21 model the problem is that the its screen display is very dim. kindly give the solution.
SOURCE: sansui hord rock 21inch eye ctv remot not working
The infrared sensor inside theTV might be faulty. Replace it. This component can be located just behind the infrared window at the front panel of the TV. You have to disassembe the TV to access it.
The component will look someshat like these.
SOURCE: Sansui B2B 21v ctv.my ctv working is good,but
Its seems to me you have faulty capacitors on the boards (it can be see if capacitor are bigger than normal)
SOURCE: What's your question?govt TV model CTV 11307 service menu code
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
