Question about Symbol Computers & Internet
//import com.googlecode.tesseract.android.TessBaseAPI; is not recognized
"cannot resolve symbol googlecode
I can't connect to the wifi, it just says Authentication problem.
You can follow the steps below to have a try and resolve this:
1. Make sure the computer is connected to WiFi.
2. Ensure Assistant for Android is installed on the device. If not, connect the device with PC via USB cable and MobiKin Assistant for Android app will be installed onto your device automatically.
3. Open the app on the device and scan QR code.
4. Choose the correct computer on the device to get connected. If it doesn't work, you can try to connect it through a USB cable. You can go to here to learn the detailed steps to make your Android device be recognized by the program.
https://www.mobikin.com/android-backup/what-to-do-if-the-device-fails-to-connect-via-wifi.html
Aug 28, 2018 | Cell Phones
My Samsung galaxy s5 the screen has gone blank. I have tried resetting several times but still blank. the blue light at the top left of the screen works and both symbols at bottom left and right work.
When your phone gets black or broken or cracked, the first thought should be attempting to rescue your data from Android phone. However, since your Android phone gets black screen or broken screen, you can't access and perform your Android phone normally as usual, and you can not export Android data by connecting your device to computer via USB cable as well, for you cannot manually enable USB debugging mode on your phone.
In this case, what should you do to recover data from Android phone with black screen? Just take it easy, you can easily resolve this problem with the Broken Android Data Extraction.
Luckily, you have the Broken Android Data Extraction now so that you can restore everything you want from your Android phone with black screen without hassle. With it, you can easily access your Android data without enabling USB debugging manually on your Android phone with black screen. It allows you to enter the Download mode to scan your device for your Android data without perform the Touch screen.
https://www.samsung-messages-backup.com/resources/recover-android-data-with-black-screen.html
Jul 04, 2018 | Samsung Cell Phones
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ...
https://androidforums.com > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from androidforums.com
SOLVED: android guy on his back - Nabi Jr - iFixit
https://www.ifixit.com/Answers/View/349279/android+guy+on+his+back Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
https://www.youtube.com/watch?v=58EPvbwPbe0
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
My tablet says it's connected to the Internet but I can't search anything with it says network issue.I know it's not my internet but there is a locked symbol beside the Internet name.How do I get this to...
Well this really depends on the application you are using to browse and the application you have used to protect your tablet with. Is this an android tablet? What browser are you using? What security software are you running? These are important questions and details that can assist you in resolving the issue.
Feb 11, 2015 | Tablets & eReaders
How to import photos from mobile to computer
Assuming you have an android device, simply connect your USB - micro usb cable to both PC and phone. Then once PC recognizes your phone, navigate to "SD CARD" and look for "DCIM" folder. that's where all the pictures are located
Jun 29, 2014 | Android Apps
Backup samsung convoy contacts to pc
Because of the importance of transferring contact information from one communication vehicle to another, there are a number of different automated ways to transfer contact information. To import contacts, such as VCF files from computer to Samsung Galaxy S9/S8/S7/S6/S6 Edge, you need to ask help from an Android data transferring program named MobiKin Assistant for Android or Assistant for Android (Mac Version). With it, you can move contacts between your Samsung Android phone and computer in 1 click.
Step 1. Click the above button to download and install MobiKin Assistant for Android on your Windows or Mac computer according to its prompt instructions. Then, launch it directly. After that, you'll be required to connect your Android phone to computer with USB cable or WiFi. Just choose the method for connecting as you like.
Step 2. After connection, you need to do some operations to make the device be recognized by the program. For example, you need to open USB debugging under "Developer" option, and install a right USB driver on the PC. (Sometimes you may need to install the USB driver manually due to unknown reasons when the automatic operation is not working well.)
Step 3. When your Android is recognized by the Android Assistant software, you can see an interface like below. Now, directly click "Super Toolkit" in the top menu, and select "Backup" option.
Step 4. Check the device and click "Contacts", then specify an output folder according to your needs. After that, click "Back Up" button to begin the process. backup-android-files-uwkecbqhxdnurjdgs33nmwp2-4-2.jpg
Complete procedure can be found on below link: 5 Ways How to Backup Android Contacts
Learn More:
How to Import Contacts to Samsung Galaxy S9 S8 S7 S6 Edge
Dec 21, 2012 | Samsung Convoy Cell Phone
How can I delete SIM contacts? All SIM contacts are bloked.
Changing the SIM lock code will resolve your issue. If it is still asking for code and you have the PUK code with you after consecutive incorrect passcodes, your SIM will be blocked then it will ask you to enter the 8digit PUK code then you will have complete access with deleting all information that you want to delete.
Dec 29, 2011 | Samsung SGH-i900 Omnia Unlocked Cellular...
How do you download flash player
With Archos 70 Internet Tablet, you need to download a specific version of Adobe Flash Player from Google Market since it runs Android OS. And A70 doesn't come with GMarket, rather Appslib, which doesn't quite cut it.
Luckily someone has made a neat little .apk file thath as Google Market, which lets you download GMarket and download/install all its apps/games/etc on your A70.
Just download the following .apk file and install it on your A70, afterwards download Adobe Flash Player from Google Market. However, this hack ONLY works on 2.2 froyo android OS, so make sure your A70 firmware is up to date.
I'd also recommend installing Dolphin Browser HD as it seems to provide a more refined flash browsing experience coupled with the Adobe Flash Player.
Link: http://archos-apps-installer.googlecode.com/files/gAppsInstaller_v5-final.apk
Dec 31, 2010 | Archos 70 eReader
StartActivity fails to launch class called
This example is working try it.
Forwarding.java
package com.example.android.apis.graphics;
import android.app.Activity;
import android.content.ActivityNotFoundException;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
public class Forwarding extends Activity
@Override
protected void onCreate(Bundle savedInstanceState)
super.onCreate(savedInstanceState);
setContentView(R.layout.forwarding);
Button goButton = (Button)findViewById(R.id.go);
goButton.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
try {
Intent intent = new Intent();
intent.setClass(Forwarding.this, ForwardTarget.class);
startActivity(intent);
finish();
} catch(Exception e) {
System.out.println(e.getMessage());
ForwardTarget
public class ForwardTarget extends Activity
@Override
setContentView(R.layout.forward_target);
AndroidManifest.xml
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.example.android.apis.graphics"
android:versionCode="1"
android:versionName="1.0.0">
<application android:icon="@drawable/icon" android:label="@string/app_name">
<activity android:name=".Forwarding"
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
<activity android:name=".ForwardTarget"/>
</application>
</manifest>
forwarding.xml
<?xml version="1.0" encoding="utf-8" ?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical" android:padding="4dip"
android:gravity="center_horizontal" android:layout_width="fill_parent"
android:layout_height="fill_parent">
<TextView android:layout_width="fill_parent"
android:layout_height="wrap_content" android:layout_weight="0"
android:paddingBottom="4dip" android:text="forwarding" />
<Button android:id="@+id/go" android:layout_width="wrap_content"
android:layout_height="wrap_content" android:text="go">
<requestFocus />
</Button>
</LinearLayout>
forward_target.xml
android:text="forward_target" />
</LinearLayout>
Nov 03, 2008 | Google Android
Computers & Internet Logo
32 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
