Question about Unique Interieur Freightliner Mt 55 Emt Fire Truck 1:32 Diecast Model
I'm in need of the serpentine belt routing for the cummings 5.9 engine
    President:
  • 986 Answers
Here you go and I hope this helps you This is for an older ctd may be the same I'm in need of the serpentine belt routing for the - jc_thinking.gif
I'm in need of the serpentine belt routing for the - fan_belt02.gif="/uploads/images/fan_belt02.gif" alt="fan_belt02.gif" class="h_mi" /> -
Read more: http://www.dieselbombers.com/5-9-liter-cr-dodge-cummins-03-07/27279-belt-routing-diagram.html#ixzz0QoyYxYyZ
Posted on Sep 11, 2009
6ya staff
SOURCE:
I need a diagram for a 2011 dodge 2500 cummings serpentine belt.
Jeff, Check the attached links,instruction and guides, diagram for a serpentine belt, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amps Belt routing Installation and system start up for 6 7L Cummins
Serpentine Belt Routing
Drive belt routing
2011 dodge 6 7 cummins serpentine belt diagram Google Search
May 22, 2016 | 2011 Dodge Ram 2500
Serpentine belt diagram for a 2003 Chevy unpalatable 4.3
Pop the hood of the car and locate the serpentine belt routing diagram. The diagram on the 2003 Chevrolet Impala is on top of the fan shroud. The diagram will be a picture of all of the accessory pulleys and how the serpentine belt is routed among the pulleys. This diagram will give you the exact direction for routing the new belt onto the pulleys. If you cannot find a serpentine belt routing diagram, take a notepad and pen and draw out the exact routing diagram of the old belt across the pulleys.
  • 2 Locate the serpentine belt tensioner. It is located below the alternator on the left front side of the engine. The tensioner on the 3.4 liter, 3.5 liter and the 3.9 liter engines will require a 3/8 ratchet to release the belt tensioner. The 3.8 liter engine will require a ratchet and a 15 mm socket for the belt tensioner. Rotate the belt tensioner clockwise to loosen and remove the belt from the belt tensioner pulley.
  • 3 Slide the old belt from the belt tensioner pulley. Remove the belt from the remaining pulleys and pull the belt from the engine compartment.
  • 4 Route the new belt across the crankshaft pulley first. The crankshaft pulley is the big pulley on the bottom of the engine in the center. Then route the serpentine belt across the remaining pulleys as directed by the serpentine belt routing diagram. Leave the belt tensioner pulley for last.
  • 5 Rotate the belt tensioner clockwise again to relieve the tension and slide the new belt across the top of the belt tensioner pulley. Release the belt tensioner and the belt will tighten up as the tensioner applies pressure to the belt. Make sure the new belt is properly seated in all the pulleys.
  • 6 Crank the engine and inspect the belt again to make sure that it stays seated in the pulleys.
  • Read more: How to Replace a Serpentine Belt on a 2003 Chevrolet Impala ' eHow.co.uk http://www.ehow.co.uk/how_6120665_replace-belt-2003-chevrolet-impala.html#ixzz1Yi6QLAjb
    Sep 21, 2011 | 2003 Chevrolet Impala
    Belt diagram for duramax diesel
    Fig. Accessory serpentine belt routing-4.3L, 5.0L and 5.7L engines without A/C
    Fig. Accessory serpentine belt routing-4.3L, 5.0L and 5.7L engines with A/C
    Fig. Accessory serpentine belt routing-6.5L Diesel engines
    Fig. Accessory serpentine belt routing-6.6L Diesel engines
    Hope this helps (remember to rate this answer).
    Dec 20, 2010 | 2000 Chevrolet 3500
    Need a serpentine belt diagram for '05 5.9L cummings
    go to autozone.com they have repair manuals and pictures of belt routing on most cars
    Dec 04, 2010 | Dodge Ram 2500 Cars & Trucks
    How do i release the tension belt ... cant seem to find bolt being referred to in other docs
    Here's the procedure on how to release and replace the tension belt of your car.
    Step 1
  • Open the hood on the Volvo S-60 and find the serpentine-belt routing diagram. The diagram should be attached to the top of the fan shroud that covers the radiator. If not, draw out the exact routing method of the serpentine belt around each pulley with a pen and a piece of paper.
  • Step 2 Locate the serpentine-belt tensioner that is in the very center of the engine. The tensioner will have a square bolt head in the center of the tensioner pulley.
  • Step 3 Slide the open end of the 5/8-wrench onto the square bolt head in the center of the belt-tensioner pulley. Turn the tensioner pulley counterclockwise and slide the serpentine belt off of the tensioner pulley.
  • Step 4 Remove the serpentine belt from the other pulleys and pull the belt out of the engine compartment.
  • Step 5 Slide the new serpentine belt into the engine compartment and around the crankshaft pulley.
  • Step 6 Route the new serpentine belt around each pulley. Turn the belt-tensioner pulley counterclockwise again and slide the serpentine belt around the tensioner pulley. Release the tensioner and it will tighten the belt around the pulleys. Look over the belt to ensure that it is inside of each pulley.
  • Step 7 Crank the S-60 and look over the serpentine belt with the motor running. Let the engine run for about one minute and shut the engine off. Close the hood.
  • Aug 12, 2010 | 2001 Volvo S60
    Looking for diagram of serpentine belt
    0996b43f80208ca1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN U) engine
    0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN S) engine
    0996b43f80208ca1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN U) engines
    0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN S) engine
    0996b43f80208c9f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.4L SHO engine
    0996b43f80208ca0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Water pump drive belt routing-Ford 3.4L SHO engine
    i wasnt sure what engine you had hope this helps good luck
    Jan 15, 2010 | 2000 Ford Taurus
    Need the routing directions on serpentine belt for a 2000 cavalier
    Not sure of your engine size since you didn't post it so please the applicable one for you. Also, please don't forget to rate! Thanks!
    Serpentine drive belt routing with A/C-GM 2.2L engine
    Serpentine drive belt routing without A/C-GM 2.2L engine
    Serpentine drive belt routing-GM 2.4L engine
    Dec 04, 2009 | 2000 Chevrolet Cavalier
    Need diagram of drive belt assembly forcaddy
    You didn't list your motor size so please pick the applicable diagram:
    Accessory serpentine belt routing—4.8L, 5.3L & 6.0L engines
    Accessory serpentine belt routing—5.7L engines with A/C
    Accessory serpentine belt routing—5.7L engines without A/C
    Accessory serpentine belt routing—6.5L Diesel engines
    Accessory serpentine belt routing—7.4L engines
    Accessory serpentine belt routing—8.1L engines
    Oct 26, 2009 | 2002 Cadillac Escalade Ext
    NEED DIAGRAM FOR ROUTING THE SERPENTINE BELT
    PLEASE DON'T FORGET TO RATE--You didn't post the size of motor so please pick the applicable one:
    Accessory serpentine belt routing—4.8L, 5.3L and 6.0L engines
    Accessory serpentine belt routing—4.3L, 5.0L and 5.7L engines without A/C
    Accessory serpentine belt routing—4.3L, 5.0L and 5.7L engines with A/C
    Oct 22, 2009 | 2004 Chevrolet Express
    Needa serpentine belt routing diagram for a 1990 F150 pickup truck
    1990 Ford F Series Pickup 6-Cyl. 4.9 L
    Automotive V-Ribbed Belt (Standard)
    Serpentine; W/A.C.; W/Auto. Trans
    Serpentine; W/A.C.; W/Man. Trans
    Serpentine; W/O A.C
    Is this engine is your model, I hope help you with this. Good luck.
    Sep 11, 2009 | 1990 Ford F150
    Unique Interieur Freightliner Mt 55 Emt Fire Truck 1:32 Diecast Model Logo
    534 people viewed this question
    Top Unique Interieur Toys Experts
    Marvin
    Marvin
    Tom Chichester
    Andrew Taylor
    Andrew Taylor
    Are you an Unique Interieur Toy Expert? Answer questions, earn points and help others
