Code shows SC 548 how do I clear this
SC548: Fusing unit installation error
- Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at
where the fuser is located). These get knocked & moved out of
postion,
this sc 548 usually happens when paper jam occurs and user does not
properly fit the fuser... also not fiitted properly due to some
foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
