Question about Hoover Washing Machines
Hoover washing machine error E4 drum empty of water pump not blocked can't get rid of error message
6ya staff
SOURCE:
Anonymous
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
Anonymous
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
danbhoy
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
Anonymous
SOURCE: Error mesage E4
E4 commonly means an overflow detected in the bottom over flow tray - try removing the kick board from the front of the machine - you should see 2 plastic black panels about 4 inches wide each, using a flat edged screwdriver pop the panels off and you will see the mechanics of the machine - the base is classed as the over flow tray - when water fills this tray a polystyrene float is pushed up and an E4 error code is detected - tilt the dishwasher back and allow the machine to dry out before trying it again - this should work unless the water seal around the filter basket is broken - in this case an engineer should be called to replace this part. Hope this Helps.
Thanks
Donna
Posted on Jul 28, 2008
Anonymous
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
Hello, there is water inside the washing machine (Hoover 750 L). How may I get rid of it , without taking the water out by myself :) Thanks
Hi - if the machine is running but not emptying check if the filter is blocked. If you do not know where the filter is or able to access it- call any machine repair engineer for free advice over the phone
Regards
Rambo160
Aug 23, 2014 | Washing Machines
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer has fault 37 and we can smell rubber burning. The drum feels very lose.
On F&P machines the inner tub floats away from the dog clutch allowing the agitator to wash without attachment to the drum. When you empty the machine the inner drum settles back on the dog clutch and can be engaged for spinning. A loose drum when full of water is probably not a fault..
37 error is pump fault. Water level not changing.
The pump may be blocked/jammed and be overheating, or it may have failed.
You'll need to unplug the power supply at the socket.
You'll need to empty the machine.
When the water level is low you can lean the machine back to access the pump motor under the tub. Turning the fan blades can sometimes dislodge the obstruction. If the fan turns freely retry the spin mode to empty the machine..
If the pump is jammed you'll have to remove it and clear the port.
Make sure you've emptied the machine as any water left in it will run out when you remove the pump.
carefully study the pump before removal. Take note of the latch which locks the pump in position. Earth wire to open spade connector. Power wires to pump via plug. Remove and clean. Replace and test.
If the pump still overheats it should be replaced or it will damage other components. The pump resistance should be more that 33ohms..
F&P reccommend pump replacement if less than 33ohms.
Good luck.....Nomess
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Mar 08, 2009 | GE S8000E
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Zanusi washing machine
If you get rid of the water from the drum chances are that the door lock will then release. Try taking the outlet pipe and laying it down over a bowl to catch the water. If it empties then the door should open in a minute or so. If it does not empty then the pump is probably blocked, and you would need to remove the hose from the bottom of the drum where it connects to the pump, but make sure you either take it outside to do it, or you do it over a bowl to catch the water, and have plenty of towels to mop up the flood. It sounds like the drum bearings have gone and the bits have gone into the pump, or filter.
Mar 05, 2007 | Zanussi FJ1254W Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
