My problem was simply that the screens where the hoses connect to the washer were clogged with rust from my well water. I cleaned them and we're back in business.
I kept getting the same NF code! I pulled out the washer turned off the water to the machine. You willl need a pipe wrench or tool to unscrew nozel. I unplugged the machine. Unscrewed the nozels put a towel down so water dont run on your floor that was left inthe line. You will see a yellow tab where the hot water hose was attached and a blue tab where the cold water was attached it has a screen on it pull the tabs with your finger or with pliers rinse well and it will remove any sediment dirt that came through the line. I rinsed mine put them in the way u took them out connect your hoses snuggly turn on the water before pushing the machine back in place to make sure it is not leaking. plug in the machine. I started my machine and it worked perfectly and the water pressure was excellent. no more code.
NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. This also can occur if there is a whole-house water softner, well-water, or very low water pressure.
Hello & Welcome to
FixYa
NF error in your washer is displayed due to no fill condition,
when the washer tries to fill but is unable to nf is displayed. Please check
the water inlet valve for any clogs and obstructions, you can also clean the
inlet to solve the issue. Please
get back to me if you have any other questions.
Kevin
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
When I start a cycle, water flows for approximately 1 minute then shuts off and I get a nF error message. I do have well water. Where do I start to try and fix this?
