To set how your phone uses the access codes and security settings, select Menu >Settings > Security.
The security code helps to protect your phone against unauthorized use. The preset code is 12345. You can change the code, and set the phone to request the code.
The PIN (UPIN) code, supplied with the SIM (USIM) card, helps to protect the card against unauthorized use.
The PIN2 (UPIN2) code, supplied with some SIM (USIM) cards, is required to access certain services.
PUK (UPUK) and PUK2 (UPUK2) codes may be supplied with the SIM (USIM) card. If you enter the PIN code incorrectly three times in succession, you are asked for the PUK code. If the codes are not supplied, contact your service provider.
The barring password is required when using the Call barring service to restrict incoming calls to and outgoing calls from your phone (network service).
To view or change the security module settings, select Menu > Settings >
Security > Security module setting
OR
can look for::
http://www.unlock-free.com/nokia-master/
good luck!
