Machine won't spin clothes dry. I've tried the spin cycle only, it will start to come up to speed then stop spinning. When running a regular load the washer will still have a gallon or more of water in it when it finishes, however it will drain when I try the spin cycle, just doesn't get clothes very dry.
Re: Machine won't spin clothes dry. I've tried the
Remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Try it with a few clothes placed along the outer walls of the drum. It has a sensor that will try to balance the load before going up to full speed but if there are no clothes or weight in the drum, it won’t start.
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
i assume the majority of the water is being pumped from the machine? if the clothes are very wet check your "fabric Select" setting and ensure you are not wahing on delecate handwash or wool wash (knits) setting, in this setting there will be a very slow or no, spin so the clothes will not stretch and have to be laid out to dry this is normal. if you are on a Permpress or regular setting the spin should be faster, also check your cycle selection is for Regular or permpress and spin is not missed .
Possible there is no switching for the cycle from the controller or there is speed limited due to sensor action for vibration. Check the leveling of the machine, if not use rubber footing to hold the machine steady. Also check the drives for friction , if so reset and lubricate.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
The clothes are wet after spinningWhen the clothes are wet at the end of a cycle, check these:Motor couplerSpin cycleSiphoningWater-inlet valveMotor couplerTo test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.Spin cycleIf the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.SiphoningIf the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.Water-inlet valveWater-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Suggestion:
1 Press and hold down 'spin' & 'dry' buttons to unlock controls.
2 Have u overloaded the machine with clothes? Reduce load.
3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle.
Three suggestions here........
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
