Hello Marc, for what you comment, you can have several possibilities of failure, first you should see the belts of the mechanics, that are not stretched or cut, on the other hand, when you press the play key, the engine should work, otherwise it does , you could have the wrong engine or the key that sends current
I sent you the link to download the service manual
I hope you can solve it and enjoy your Sansui
Greetings Franco Dosil
Hola Marc, por lo que comentas, puedes tener varias posibilidades de falla, primero deberias ver las correas de la mecanica, que no se encuentren estiradas o cortadas, por otro lado, cuando presionas la tecla play, el motor deberia funcionar, sino lo hace, podrias tener mal el motor o la llave que le envia corriente
Te envio el link para que descargues el manual de servicio
Espero puedas resolverlo y disfrutar de tu Sansui
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Sansui-SC-2000-Service-Manual.pdf
Elektrotanya for electronics experts
https://www.hifiengine.com/manual_library/sansui/sc-2000.shtml
Finalize is for multiple recordings. If its a single recording, its finalized by itself.
SOURCE: Sansui SC-1110 won't run at correct speed.
Check the Cassette drive motor. in the back of the motor there is a Speed adjuster. there is a Hole with a rubbler **** cover use tiny strait edge screw driver. turn clockwise and motor will speed up. easy way put in a cassette you know well and use that to adjust speed.
SOURCE: Device has record turn-table, CD
the turntable belt has likely broken, you may be able to fix it with a rupper band of suitable size.
SOURCE: SANSUI SC-2100 RECORDING PROBLEM
First try cleaning the heads with some electronics grade alcohol and a static free cleaning swab...although it sounds like the head may need alignment...if those two things do not work out for you, the capstan motor might be the culprit.
