Question about Ricoh Aficio 1027 All-In-One Laser Printer
SC543 ricoh Aficio 1027
Code SC543..pls help me to solve this problem
  • 162 Answers
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Posted on Sep 02, 2009
Ricoh 1027 sc 541 sc546
Posted on May 08, 2011
  • Ricoh Expert
  • 422 Answers
You need to enter service mode to clear this, it is a heating problem with the fuser section, take it out (2 screws) are the 2 rollers touching eachother all the way across? If not this is the root of the problem. -Carl
Posted on Aug 14, 2009
6ya staff
SOURCE:
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Driver af1027 for scanner microsoft x764
Good afternoon from Chicago, shiva262,
I'm not sure from your post above, but it appears that you are looking for a driver for your Ricoh Aficio 1027 All-In-One Laser Printer. If that is in fact the case, try the following steps to resolve your problem:
1. If your Ricoh Aficio 1027 All-In-One Laser Printer is connected to a Windows-based PC, use Windows Update to try and locate, dwnload and install the correct driver software.
2. Navigate to the following links and follow the instructions:
http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio1027.pdf
http://www.ricoh-usa.com/downloads/popup/popup_manuals_drivers_download.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1022_27/x1022_27en.htm
I hope these are helpful in solving your problem. Good luck!
Regards,
Enolram
Mar 01, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Tengo na Impresora Ricoh Aficio 250 y me aparece en pantalla (PROBLEMA SC543) y no me Copias Sacar vu. les agradeceria me ayuudaran Con Este Problema
SC543 is caused by a defective Fusing thermistor. check or replace both center and end thermistor this will solve your problem
Nov 25, 2010 | Ricoh Aficio 250 Copier
Ricoh 1027 what is the scan option part number?
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
Oct 07, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
The wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Mar 16, 2009 | Ricoh Aficio 355 All-In-One Laser Printer
RICOH AFICIO 650 WHAT DOES THIS ERROR CODE MEANS SC543-00
Try changing the termistor, must be damaged. and reset by total clear, 107 and press and hold the clear stop key more of 3 seconds.
Dec 03, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
1,824 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
