Shows connected but with a lock icon next to the wifi signal icon
SOURCE: wifi is not working
try to update rom image or radio image to newest version if nothing is change down to your device rom image file
SOURCE: WIFI not working
Send it back to HP, they will fix it even if its out of warranty:
HP Limited Warranty Service Enhancetment.
SOURCE: LG Dare locks while typing a text message.
You have to go into touch settings of the "settings and tools" menu and shut off "AUTO LOCK"
What is happening is that the phone locks after so many seconds of inactivity.
SOURCE: WIFI Connection Problem - connects only to EDGE
If you want to use wifi only when your at home you can go in and manually disable the cellular data so the internet will only be wifi based. Probably saving you MB's and data cost.
Go to Settings, General, Network, then simply turn off the Cellular Data. Then it won't connect anymore to the cell data and rely only on wifi when your connected to it.
And simple follow the same steps and revers the process when your out on the go.
Thanks
Goto wifi settings of your Sony Ericsson X8 Android Mobile
press menu button and select "Advanced"
Disable the "Use Static IP" (please be confirmed that DHCP server runs on your router)
Courtesy: [email protected]
