Question about Canon Cameras
Canon elph 330hs camera-back screen is black when I take a picture. Pictures taken prior to this problem can be seen on the camera-back screen, but pictures after this problem show only black
6ya staff
SOURCE:
Anonymous
  • 849 Answers
SOURCE: black pictures
it is worth to repair instead getting new, contact your panasonic service center
Posted on Oct 27, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: No image on Cybershot DSC-T1
It is known problem of bad ccd imager in Sony DSC-T1 Cyebershot camera and ccd imager will be replaced.
Sony will repair this camera free of cost for ccd imager problem as per announced scheme. You will be charged $20 for shipment.
Click Sony CCD Imager Support fro details.
Posted on Apr 12, 2009
Anonymous
  • 4 Answers
SOURCE: Black screen for Shooting Canon S3 IS
I have a similar problem with my Canon S3 IS. Dark/black LCD in Shooting mode. However, I can view my existing photos in Display mode. I was about to spend money to get a Panasonic TZ5. Somehow I bumped into a solution post for S2 IS. Here is the link:
http://www.fixya.com/support/t1090569-black_screen
I tried their solutions twice and it WORKS. My S3 is working fine now.
Posted on May 28, 2009
Anonymous
  • 5 Answers
SOURCE: Canon Power Shot SD 400 Digital Elph - image not on screen
On most canon elph cameras you can either go through the menu and reset back to factory default and this might solve the black or white screen. If that does not work you should be able to hold the menu button down for several seconds until a reset prompt pops up. You will then click on yes for reset and this should completely reset the camera and the screen should be back to normal.
Posted on Jun 10, 2009
Anonymous
  • 5 Answers
SOURCE: Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Posted on Jun 18, 2009
My screen is black and will not display images to shoot. Also when picture is taken it plays back as black image. Previously taken pictures will display.
Michele, a stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 19, 2011 | Canon PowerShot SD960 IS Digital Camera
Canon elph 880 can display pic's but can't take a pic,,,,screen remains black and new pics are black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 01, 2010 | Canon PowerShot SD880 IS / Digital IXUS...
Screen is black....will not display whats being taken a picture of nor is taking pictures.
Am assuming that you've already tried pressing the DISP button on the back of your camera. Is it not taking pictures, or are the pictures it is taking also black like the LCD? If black pictures, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I can view prior photo's taken but. it will not take pictures. view finder is black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 21, 2009 | Canon PowerShot S2 IS Digital Camera
Black screen while shooting, but still taking pictures not black
Nonononooooo fotomohamed, he can review just taken pictures on the LCD. The screen is working.
Actually, it sounds like you just accidentally pressed the DISPLAY button on the back of your camera. This manually turns the screen on and off in picture taking mode to save batteries (you would then use optical viewfinder). Just press it once and it should turn back on.
Jun 19, 2009 | Canon PowerShot SD1000 Digital Camera
Jun 10, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Took pictures even when screen was black, now shows black picture
CCD IMAGER FAILURE !
u can call Canon and try for free repairs they have issued service advisory for various models i am sure they will cover it free of cost just give them a call in ur area and they will send a postage paid envelope for that
see this link for help on this problem
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls Rate me FIXYA for help
Apr 03, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
Mine started working again. The only thing I can attribute to it is that I zoomed the lens in and out several times. The next time I turned it on, it worked. Go figure. I'll update if things change.
Dec 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Viewing screen is black
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
Nov 08, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
