LCD TV WONT POWER ON
Yesterday my LCD TV would not turn on. The TV was working fine, I turned it off, came back an hour later and when I hit Power nothing happens. I moved to 3 different outlets in my house and nothing. No lights, nothing, it just seems dead. Please help
  • 2 more comments
  • Ack56 Nov 28, 2007
    Thanks dodgecharger,
    It is strange b/c the TV was working perfectly, then all of a sudden wouldn't turn on. I am not good with electronics (i.e. changing the fuse), would you suggest that I bring the TV to my local television repair shop?
    Thanks so much
  • bhhunt Jan 04, 2009
    I have a similar problem. The indicator light changes color, indicating the tv is on; but the screen doesn't light up. It will eventually, but sometimes it takes 15 - 30 minutes before it actually comes on. It seems to work faster when the room is warmer.
  • destin2wen35 Feb 09, 2009
    I have the same problem, but I see a red light flashing on the word lamp. I am thinking something needs to be replaced.
  • Anonymous Mar 27, 2014
    looking to fix asap
    Novelist:
    Champion:
  • 254 Answers
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Posted on Nov 28, 2007
  • Anonymous Nov 28, 2007
    hey, first, have you tried both the hand remote and the on-set buttons? These sometimes stop functioning (broken buttons, worn out contact on the pad inside remote box).
    Yes, assuming a reputable repair center is available (set isn't under warranty is it?).
    If it is a high dollar quality set, then by all means take it in. Personally, I haven't worked on any flat panel TV sets, but the common failures above apply to various electronics.
    A failure like you describe- perhaps something died in the standby circuit (a small portion of the circuit is always powered on to respond to power on command). Or, at the moment you went to power set on, something failed right at that moment.
I just had good news in fixing my Vizio L6 that suddenly completely died. I have a little electronic experience. I pulled the back off, and removed the cover to the main board and power supply. The fuse checked out okay, but no DC power was being sent to the main circuit board. I removed the power supply circuit board, and checking the bottom, i found a bad solder joint. Soldered that up, and now the set is running fine. Best case scenerio. Good luck Nick
Posted on Jun 13, 2009
My daughter turned it off and now it wont turn back on
Now the tv LED power light indication is flashing?Yes.Tries tv unplug,replug back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If tv have same result problems or again later on.The tv power supply board is the causes and the problems,that the board where the power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 21, 2011 | Insignia 42" LCD Flat-Panel HDTV
Last night I was watching TV just fine. I turned off the TV when I went to bed and then tried to turn it back on this morning when I got up. It wont turn back on and I have checked to make sure that there...
Check ur power source?Tries tv unplug,replug the tv back like about an hour later.Now the tv are resetting it self back to the factory setting.The tv should work now.If still have the same problems,some how ur power supply board is causes and is not providing the tv the wright voltages anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
Does not turn on when hit power button
Check the power source?Tries tv unplug.replug it back like an hour later.Now the tv is resetting itself back to the factory setting.The tv should work now,if not it is the power supply board is causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Dec 03, 2010 | Samsung LNT4066F 40 in. LCD Television
32" samsung tv wont turn on standby light stays red but it wont change with remote or by preesing it
Tries unplug,replug the tv back like an hour later.The tv,now will reset itself back to the factory setting.The tv should work now.If not,this problems,usally the cause it by the power supply board not responing and giving the the right voltages to the tv anymore.Tries websites like Shopjimy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 22, 2010 | Samsung LN32A330 32 in. LCD TV
Plasma wont turn on.try to turn on with remote green light comes on for a second and then turns off again.no sound or picture
Try tv unplug,replug it an hour later.Let the tv reset it self back to factory setting.Now tv,should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | LG 32LG30 32 in. LCD HDTV
My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
1,191 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
