WHEN I PLUG THE PHILIPS 42PF722OA/37 IN NO PICTURE GREEN POWER LIGHT COMES ON THEN GOES OFF RED LIGHT BLINKS SEVEN TIMES.
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Change the main power board
red and green blinking power light
