I am looking for a replacement seat unit and hood for Quinny speedi sx. Original is black and red but would consider any colour. Please contact me if you can help.
You can order from your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
RRP for Quinny Speedi front wheel unit is 27GBP RRP for Quinny Speedi rear wheel (each) is 37GBP
There would be a p+p charge of 3.99GBP or 8GBP on an order placed direct depending on the weight of the final order.
Go to www.quinny.com and select the country you're in, then select the "Contact Us" tab on the right side of the screen for your enquiry to go through to the customer care department in your country. You can order spare part items direct with the customer care team or via your local Quinny retailer.
The quinny speedi should come with the adaptors to fit the bassinet (the quinny dreami) Once you remove the pushchair seat unit by undoing the clips and undoing the velcro the fastenings you then need to remove the 2covers or bumper bar(depends on model) above the quinny logo on the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. The carrycot is then place onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood.
HTH
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know.HTH
