Hyundai DVD-360A DVD Player Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear hub caps overheating - Hyundai DVD-360A DVD Player
Anonymous
Level 2:
  • Expert 454 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
Answers
454
Questions
0
Helped
178856
Points
793
Stop riding the brakes then.
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Where do i look to see how much gear oil i have in drive shaft gerabox1982 gs suzuki l 1100
Since the other "answers" failed to note that this is a shaft-drive bike and the OP asked about GEAR oil and not engine oil....
On the side of the rear hub that has the shaft drive, look near the top of the hub. There should be a filler-cap of some sort. Usually on the face of the hub, but above the center-line and slightly to the rear
Put the bike on a level surface and put on the center stand (or have a friend hold the bike level). remove the filler-cap (inspection cap). The gear oil level should just start to be at the lowest point of the opening for the cap.
Remove rear hub on1996 prelude
Just use a chisel or big flat blade and go along the groove between the cap and the hub. It will come off.
5helpful
How to change a rear wheel bearing on a 2004 ford taurus???
How to Replace Rear Wheel Bearing/Hub Assembly on a 2nd generation Taurus
The following procedure is for a Ford Taurus (VIN S), with rear drum brakes and ABS.
1. Loosen wheel lug nuts, raise rear of vehicle, and support securely on jack stands. Block front wheels and remove rear wheels.
2. Remove brake drum (parking brake must be off).
3. Remove and clean ABS Sensor (Torx E8) with a spritzled rag.
4. Remove grease cap from hub.
5. Remove and discard hub retaining nut (36 mm). This is a compound nut, comprised of several nuts inside a metal cage. Use a 36 mm axle nut socket (e.g., OEM 25206). Many auto parts stores will lend you this socket. A 1/2-inch drive air impact wrench or breaker bar is necessary to remove the nut.
6. Remove wheel bearing/hub assembly from spindle. It easily comes off by hand.
7. Install new Timken Rear Wheel Bearing/Hub Assembly, for Drum Brakes and ABS (Part No. 512162). Tighten new axle spindle nut (Dorman 05114) 221 lb.-ft., replace grease cap, and button everything up.
1helpful
2answers
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Remove rear hub for shoe replacement on 1998 grand
If the rear hub is removable there will be a metal cap covering the nut. You generally don't have to remove the hub to replace brake shoes though.
5helpful
How to change a rear wheel bearing on a 1994 toyota camry
The rear wheel bearing on a toyota camry is replaced by replacing the wheel bearing and hub as a unit. this is a design change as compare to older models with two piece wheel bearings. Scotch drive wheels. Remove rear wheel. Remove rear brake drum. (note: if emergency brakes are applied you will not be able to remove brake drum) Remove dust cap and hub retaining nut. Hub should slide off as unit. Replace hub with new unit. Installation is reverse of removal.
9helpful
I need instructions on how to replace rear wheel bearings on my 1994 Honda Civic
Bearings are pressed into the hubs...much easier, faster and economical (if you don't have a press) to replace the complete bearing/hub assembly, no pressing is needed, since bearings are already pressed into the new hubs. Cost..aprox, 60 buxs each.
Here are the steps for the rear replacement...
Loosen the lug nuts on a rear wheel. 2) Chock the wheels and jack the rear of the car on the side with the lug nuts that you just loosened. 3) Remove the wheel by removing the lug nuts. 4) Pry open the dust cap covering the center of the axle/spindle. A small screwdriver tapped into the space between the hub and dust cap will work well for this. 5) With the dust cap now removed, use a thin center punch to straighten the little dent in the rim of the spindle nut so that you will be able to turn it freely in the next step. 6) Use a 32mm socket and a large breaker-bar to loosen the spindle nut. Unscrew the nut all the way and place it in a clean, safe area. 7) You should now be able to slide the hub/bearing assembly from the shaft. 8) Installation is the reverse of removal. Use plenty of high-temperature wheel bearing grease on all surfaces before you mount the replacement hub assembly.
IMPORTANT: Torque the spindle nut to 134 ft/lbs....(per manual specs)
When reinstalling the dust caps, tap them gently into place to avoid denting them...Install wheels, jack her down and pat yourself on the back...job complete.
Good luck..hope this will fixya up...please take time to leave me a fixya rateing...
1helpful
How do i change rear hub
remove brake drum and center dust cap..remove nut holding hub and pull hub off spindle..use a new nut also..tighten securely
Rear wheel hub
IF IT HAS REAR DRUM,WITH WHEEL REMOVED,REMOVE BRAKE DRUM,KNOCK OFF CENTER BEARING CAP,REMOVE STAKED LOCK NUT,AND PULL OF HUB AND BEARING ASSEMBLY.
Top Hyundai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
