When my MAH3000AWW gets to spin cycle it just slowly rotates each direction. The door lock light never comes on.
This is a problem that a lot of early neptune models had. it is most likely the wax motor on the door lock assembly is bad and needs replaced. but, almost every time that I've had that wax motor go out, it has blown the board also, therefore you also need to replace the control board. to see if the board is bad, you need to remove the 3 screws on the top of the control panel. then the panel slides forward a little and roll the top toward you. you will see the control board there. it is a large board, if the wax motor blew it, the R-11 resistor will be blown. it is easier to just look for a black spot on the board, if you do then see which one is blown and look at the numbers for that resistor. if it is the R-11 that is blown, then the board and wax motor need replaced. just a warning, the board is around $200. if you check this and that is not the problem, let me know. there are a couple other things that can cause your issue, but this is by far the most common, and unfortunately, the most expensive. good luck, shane.
