Question about Tektronix Phaser 860DP Thermal Printer
Phaser 850 displays -close top cover to continue
This display comes on whenever i turn on machine and will not allow me to go any further can this be fixed without a tech?
6ya staff
SOURCE:
Robert Seeley
SOURCE: tektronics phaser 850 - media jam
Exactly what 2 of mine are doing. I have no clue on how to fix this so if you find a solution let me know via e-mail if you can. My e-mail is Seeley4859@gmail.com
Thank You
Posted on Jul 09, 2008
Rick Kasper
  • 2072 Answers
SOURCE: xerox phaser 8400 message
What has most likely happened it the tab that actuates the cover switch has broken off. What you want to do it open that cover and look around the edge where it meets up with the other cover. There will be a hole, I would say about a half inch long and about a quarter inch wide where there will be a switch. Look at the exit cover in that area and you will probably see where a tab was, and is not broken off. You normally can fix it by making a couple of small holes in the cover and epoxying a paper clip in that area as a new switch actuator. You have to break or cut the paper clip to the proper length and so you have 2 ends to pop through the cover and epoxy it to.
Posted on Oct 04, 2008
Rick Kasper
  • 2072 Answers
SOURCE: Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Posted on Mar 31, 2009
Renierf
  • 97 Answers
SOURCE: Front cover of phaser 8550 won't close correctly
You can download the service manual free at ww.eserviceinfo.com
Posted on Aug 19, 2009
ikkenom
  • 10406 Answers
SOURCE: Xerox Phaser 8400 Front Cover Open
Yes, there is an OPEN/CLOSE sensor that is sending wrong "status" information to the printer.
Posted on Jun 01, 2010
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
Code LL flashing. Will not complete a cycle.
The LL error code is not documented very well.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket. See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Jul 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How so I remove the old prinhead and install a new one
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. Scroll to the Printhead menu icon (icon on the lower right of the front panel display) and press Enter.
  4. Scroll to Replace Printheads and press Enter.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. When instructed, open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts in all carriage slots and on all printheads (instructions below).
  10. Allow the contacts to dry.
  11. install the new printheads and close the carriage cover.
  12. Close the top cover.
  13. Turn the printer on and attempt to verify functionality.
Apr 18, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer error 15.004.45.433219 on Tektronix Phaser 860dp
Hi juniorgona:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Hope that this helps.
Apr 08, 2009 | Office Equipment & Supplies
Xerox tektronics phaser 850- media jam
The preheat entry sensor assembly probably has broken sensor arms, and will need replaced.
Jun 13, 2008 | Xerox Phaser 850 Printer
STATES THAT TO CLOSE TOP COVER TO CONTINUE
1. The top cover hinges are not connected to the ink slider bar properly. - Open the top cover and snap the hinge arms back into place and close the top cover. Check for proper operation. 2. Customer has not loaded the ink sticks properly and the top cover will not close properly. - Verify the ink sticks are loaded properly and that the customer is using proper Phaser 860 ink sticks. Close the top cover and check for proper operation. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 200469000 1 COVER; TOP COVER
May 22, 2008 | Xerox Phaser 8200 Laser Printer
Close front cover message
Well here is what I can tell you.
Open the front cover. Staring you right in the face should be a bar code/number sticker. Look forward from that and there shoule be a small plastic tab, about a half inch long and less then the thickness of a popsicle stick. It is the front cover interlock switch actuator. It may be broken off.
Or look for the opening where that tab should slide into the machine the switch may be dislogded or broken.
Probably that tab has broken off not actuating the switch on that cover.
Dec 29, 2007 | Xerox Phaser 8500/DN Printer
Tektronix Phaser 860DP Thermal Printer Logo
51 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
Vincent G
Vincent G
STEVE
Vuk B
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
