I REPLACED THE BLADES AND THE RELAY SWITCH AND THE PULL SWITCH AND ALSO THE CLUTCH AND THE BLADES WILL NOT TURN ON WHEN THE SWITCH IS PULLED. ANY HELP WILL BE GREAT !!!! THANS ROBIN
Having had the same problem on mine, it turned out to be the connection to the fuse under the instrument panel. After I cleaned the contacts on the fuse, it worked great. Also, I had to eventually apply some contact grease to keep it from repeating the problem every couple of weeks. Since then, I haven't had the issue for 2 years.
IF PETROL REPLACE SPARK PLUG.
