Its an assurance modelans
SOURCE: i keep getting the process android.process error
this happened to me everytime i tryed to add a contact. it somehow deleted all my contacts but with a simple SD card restore 1st then a factory reset (yes pain in the **** you lose all your apps and data) everything should work good as new, well atleast for me :)
SOURCE: the process android.process.acore has stopped
please try to reset its because of the software corruption it usually happens in Htc models...
1.Phone turned off, press and hold the HOME and BACK buttons,
and then briefly press the END CALL/POWER button. The reset process will
start after a few seconds.
2. Wait for the phone to finish the reset process and then press MENU.
if it does not solve upgrade to latest firmware
Update to latest version
http://www.htc.com/www/support.aspx
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
SOURCE: i get a force close message on my phone. what do i
This basically means the OS is having severe problems. You need to try a master reset first. If this does not work and there is no software update available from the HTC website you need a replacement handset.
SOURCE: I keep getting the error message "The process
The easiest way to solve this is to do a factory reset.
To do one follow these steps:
Slide open keyboard
Press Alt and L at the same time you will get a screen with some options listed
Press Alt and W at the same time to wipe device to factory reset
Once it is finished press home and back key at the same tim
Remove the battery
Reinsert the battery
This should fix your problem but note that it will wipe all of your apps from the phone and you will have to connected the phone with gmail again.
SOURCE: my pandigital keep makeing me forceclose evrythingand i cant do nothing
It may the processor problem. or reinstall it and see.
Another method is to contact the supplier for help if you could not fix it.
Android 4.0 Tablet PC
