I have a message that's been on my screen for the past few hours. It won't go away. It's telling me to tell a Mitsubishi service advisor the code and in return he will give me a five digit code that I'm supposed to enter into my keypad.
It says to press MENU to exit, but that's not working.
I turned it off and back on after a few minutes and the message is still up. What should I do?
SOURCE: Entering Service Menu
OPTION MENU "MENU 0170" SERVICE MENU "MENU 0157" CONVERGENCE MENU "MENU 0159, 4 FINE, 5 COARSE, 6 MISC." By pressing Menu then #
SOURCE: WD-52327 Lamp hour indicator.
Found this in another forum. So apologies if there are any innacuracies.
service code
menu-5-7-5-7
Press the "AUDIO" button on a remote hand unit to select an adjustment function.
Press the ?VIDEO? button to select a specific adjustment Item.
After selecting an adjustment Item, use the ?ADJUST UP/DOWN? buttons to change data.
? Press ?ADJUST DOWN? to decrease the data value.
? Press ?ADJUST UP? to increase the data value.
Press ?ENTER? to save adjustment data in memory. The character display turns red for approximately one second in this step.
Press the ?MENU? button on the remote hand unit twice to terminate the adjustment mode.
options code
menu-5-7-7-0
SOURCE: Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
SOURCE: Mitsubishi WD-62528 error code 45
go to the manufacture site they should tell you what the code means if not try techlore.com
SOURCE: I have a Mitsubishi medallion 65 and it keeps turning off,
Dear Sir,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. I hope this helped.
Good Luck, big IRISH.
Clearly you have a problem that Mitsubishi can give you better guidance on. I suggest you either e-mail or call Mitsubishi with your "service code 454" info...or call an authroized service rep (he should have the info on service codes). for more guidance. Service codes may mean your set does need, in fact, some real service (cleaning, cooling problem, lamp problem, etc)
