No liner. Could drain lines and pumps and leave pool partially full.
If you leave it up, drain down past flow lines. We use a tarp. It will still get dirty and green, and is hard to clean in 72* degree water. Takes a long time to warm up. Sometimes we leave it up, mostly we clean out and take down, to level yard next year.( moles, sides sinking, or damage to rusted legs. I personally would take it down. Start fresh. Mine is salt water, 9 X 18 and have had it for nine years. Good luck.
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
SOURCE: Hi, We have the above
do not cut anything
all intex pools come preformed,holes cut, and ready to go
go to intex.com and pull up the manuals in pdf form and watch the videos on there web site also
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
SOURCE: Hi, I have let my
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
SOURCE: I purchased an Intex 1500
They are so cheap, just buy a new one. Intex filters and pumps are essentially "disposable" products, and typically dont last more than 2 years
