I have a Ricoh Aficio 2035 all-in-one laser machine. When I want to print labels from a Word document, I go to Properties, choose Bypass Tray, choose Labels, and then OK. But the printer takes the paper from Tray I instead. If I pull out all trays, I can stop this. Then I have the option of going to the printer and choosing the Bypass Tray, but the printer expects plain paper from that tray and so does not fuse the toner properly onto the labels.
There are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
