Question about Premiere Microscopes MRJ-03 Microscope
The fine knob on my MRJ-03 is loose and keeps spinning even after i stop touching it. How can i fix this?
My premiere microscope MS-01 Ultra will not focus
There is what is called a "stage stop" screw. Its purpose is to limit the specimen from rising high enough to contact the objective lens. The "stage stop" screw is directly behind the black stage platform in plain sight and very easy to access. It is a thumb screw and sits vertically. Simply loosen it a bit to allow the specimen to rise high enough to focus.
Jul 25, 2010 | Premiere Microscopes MRJ-03 Microscope
Ignitor keeps clicking. How can I fix it, or do
There are switches behind the knobs that turn the spark igniters on when they are turned. they usually slide over the shaft and have two wires coming out of them. They are usually wired in series so the way I check them is to unplug the machine and disconnect the last one first then plug it back in. and repeat this until the clicking stops. when it stops you found the switch that is faulty. Take your model number into your local service shop and they can order one for you.Be carefulnot to let the wires touch metal because thes are live when plugged in.
Jun 27, 2010 | Hotpoint RGB745 Gas Kitchen Range
The roller that spins with little brushes stopped suddenly and no longer spins. I pressed the red little knob at the end of the roller but it doesn't fix the problem.
open up the roller area check to see if somthing got picked up and jammed into the rollers so that it can't work, a rock or a screw or you might even have a large amount of string or fibers wrapped around the shaft or brush keeping it from rolling
Feb 19, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I need ti find a spare electric board for a PREMIERE MRJ-03.
Check the cable connections, a cable might be loose or just disconnected.
May 08, 2009 | Premiere Microscopes MRJ-03 Microscope
I own a MRJ-03 Premiere microscope with the a bad electric board. How can I get spare parts for it? abnernm@hotmail.com
I have the same problem and can't find parts anywhere. Premiere Microscopes doesn't answer their phone or return calls and their customer service email keeps rejecting everything I send. Please let me know too if there are parts available for this microscope.
Robbie.Dietrich@gmail.com
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Right ascesion slow motion control knob loose, does not work
The RA knob has a setscrew that fixes it to the shaft. Just need to find the correct size and tighten.
Jul 06, 2008 | Meade LX200GPS Telescope
Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Apr 17, 2008 | Cooktops
Premiere Microscopes MRJ-03 Microscope Logo
Top Premiere Microscopes Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Premiere Microscopes Science and Laboratory Expert? Answer questions, earn points and help others
