Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
Just bought HDTV Christmas - some of the stations are cutting out, others are not. What is the problem and is it something that can be fixed at home?
  • 864 Answers
Could be an antenna problem. See www.dtvanswers.com for more info.
Posted on Aug 12, 2009
6ya staff
SOURCE:
I bought my husband a 2 pc. chainsaw set. Blue Max 14"-20" It will not stay powered up to make a cut, after it is started. We need to know where to take it for service, or what process is needed for a
A good idea to take it to home depot. Some of them have stations that work on fixing power tools and other things that break often. As for your problem it seems as if there is some sort of connection problem with the battery. Whenever you move it may jostle the connection enough to cut it off there for turning of the chainsaw. If you can check they battery and see if there are any loose cables that may help and if not take it to home depot.
Jan 29, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
RCA HDTV D52W23- words in 3D - picture at top and bottom black
are you still having this prob? i am having a similar prob with the same brand of tv. if you had yours fixed please help me with mine.
i think it is the convergence ic. i need three ic but the distributer will nit sell no less than ten of them. if you or anyone need any of those ic i could let you some for the same unit price i bought them. posted 09/02/2009
Jun 28, 2009 | RCA D52W23 52" HDTV CRT TV
Displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Feb 23, 2009 | Samsung Televison & Video
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Wii charge station doesn't appear to be working, no light indicator coming on and it was bought new at christmas and we have only started using it in february - help
Who is the manufacturer? I have been through three different charge stations since Christmas. React RT530 is the one we are on now and so far so good.
Apr 18, 2008 | Video Game Consoles & Games
Brew Station Model 47214
Since it's still under warranty, I would contact Hamilton Beach Customer Service in Canada and see what they would do for you.
They may even be able to talk you through figuring out what's wrong with it and sending you a part to fix it yourself. Technically, it should be replaced but sending it back at your own expense might end up costing you almost as much as the coffemaker cost to begin with.
Hamilton Beach Canada 1-800-267-2826
Feb 21, 2008 | Hamilton Beach BrewStation 47214 Coffee...
SNES Game/System incompatibility?
check your connections, try cleaning your snes system with some rubbing alcohol (the party where the game connects to the system), you might have to take it apart to do that...
one way we use to do with the NES was cut a piece of paper out to fit inside the game, make it wet with rubbing alcohol, then push the game in and pull it out a few times (of course if the paper gets stuck you'll have to take it apart to get it out.
SNES's are pretty cheap so u may have to purchase a new one
Jan 06, 2008 | Nintendo Super NES Console
Sony LCD Digital Color TV Model KDL26M300
If you only have basic cable with no cable box this may be normal. You may need to upgrade your service or get a cable box.
Dec 18, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
