Question about Philips 50PFP5332D 50 in. Plasma Television
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
We have a Philips 50 inch plasma TV model no. 50PF7320A/37. When we turn it on the green light comes and then we get a second click and the flashing red light comes on. We have turned it off, unplugged it and waited and have on occasion gotten it to come back on. We are now at the point where it will not turn on at all. any suggestions?
    President:
  • 1,077 Answers
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Posted on Aug 12, 2009
  • 2 more comments
  • Jay Finke
    Jay Finke Jan 30, 2011
    hey thanks man, i'm going to give it a try. I had good luck with my last flat tv repair, wish me luck .. jay the pool pump repair guy.. and tv, I hope....... PRIME THAT PUMP !!
  • Raymond Quirke
    Raymond Quirke Dec 22, 2013
    Hey Jay,
  • Raymond Quirke
    Hey Jay,
  • Raymond Quirke
    I've the same tv and he same problem. How did you get on?
    New Friend:
Philips 50PF7320A NO VIDEO
Posted on Mar 14, 2010
6ya staff
SOURCE:
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
OUR 50 INCH HD AMBLIGHT PLASMA MODEL 50PF9631D HAS SOUND BUT THE PICTURE HAS MANY LINES ANY IDEAS ON WHAT THE PROBLEM IS AND HOW TO FIX??
This is know as the" Blue Haze" defect. A tech may try to lower the screen voltages for you. Realign Ve, 110volts to 100volts. Vset from 195volts to 188volts...and the Vs from 197volts to 190volts. This was an authorized fix early in 2007. But more importantly you will have to live with this, as replacing the plasma screen is very costly. You probably have a bad screen.....SORRY!!!!!!
Oct 20, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Hello, i have a 50 inch philips flat tv model # 50pf7320a/35. why is the screen half black?
Unfortunately, i have found in my experience is when this problem occours you need to replace the plasma panel, which can be a costly thing to do and takes a little bit of planned time. Other than that you can try to replace the X-sus printed circuit board or the Y-sus printed circuit board. Those two boards control the screen circuitry, Good Luck.
Sep 26, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Thin horizontal line,about 6 inches from bottom,is it fixable?
I am assuming it goes all the way across and is black ?
It sounds like a scan line in one of the chips inside has gone bad or needs to be resoldered. Most likely needs the board replaced by a tech.
Hope this helps
Scott
Mar 30, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 50" plasma ysus board troubles
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
My 50 inch plasma
We have a 50 inch magnavox plasma screen. We found and used a fix from fixya! It only costs us $34.00 campared to the $300.00+
anyone wanted to look at it. The problem was on the powerboard but was two little capacitators with the model #3300 10v. We carefully took the back off the tv and removed the power board, went to a local electric supply store and bought the 2 parts for $2 each, we then found someone (tv repair shop!) to sauter the new ones on! Got it home put it back together and it stayed on, no depressing shutdown after a few seconds! you can find a picture of a fried capacitator on yahoo images, they are supposed to be flat but if defective will be bubbled at the top or even split! I am calling Magnavox today to complain that they are not recalling this part that should have been a better quality capacitator! Hope this helps some people!!
May 23, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Plasma tv
We have the red, white, yellow cable connections in the back connected but find no way to get PlayStation II to play on the TV for the grandchildren.
Thanks.
Dan
Feb 29, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips plasma 42pf5520d pictures has gone?
My Philips Plasma TV model 42PF7220A/37 went into "no menu exit" mode on 11/28/2007. I went to www.usasupport.philips.com and downloaded an upgrade. Just followed the instructions and my TV is all better.
Nov 21, 2007 | Philips 42PF9630A 42 in. Plasma Television
Philips 50PFP5332D 50 in. Plasma Television Logo
2,904 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
