Jenn-Air JSD2789GES Side by Side Refrigerator Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The refrigerator makes a noise about every 4 minutes, like a it is trying to start something i don't think it is the ice maker
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Aug 12, 2009
Anonymous
Expert
Level 2:
Answers
77
Questions
Helped
22184
Points
193
Sounds like ice maker . when noise is happening open freezer and listen to the ice maker and see .. it could be ice stuck in the ice maker and needs to be freed up......
  • Anonymous Aug 12, 2009
    sounds like ice maker . when noise is happening open freezer and listen to the ice maker and see .. it could be ice stuck in the ice maker and needs to be freed up......
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
5helpful
I have a GE side by side refrigerator with ice maker. Refrigerator has been fine and now it just started making a loud like humming noise which is coming from the freezer the ice maker works when I open...
Sorry to read about your problem, I hope this helps you out.
it maybe your fan, going bad. or you have a ice build up, and its hitting the fan..if this is the case, you have a defrost issue. or a bad fan.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
I have a Samsung RB19ZASH. The ice maker makes ice, but when it empties the ice tray, the ice comes out fine, but the ice maker starts making a loud poping noise for about a minute after. Then, it will...
I think maybe there is a number missing in your model number. But I may be able to help you.You model came with different type of icemakers and some were mechanical and some were electronic. My concern is the popping noise you hear. I just found the part and your model is a RB195ZASH The main component of the ice maker is part number DA97-00258E I think you may need someone to have a look at the ice maker and make sure its not binding while rotating or the defrost heater may be remaining on. There also could be parts that are replaceable for your model but I will need to search for the complete parts list. I will do that for you and send you some links soon, Thanks Sea Breeze
1helpful
Buzzing noise every 5 to 10 minutes, like an ice machine turning
No ,very possible it is due to expansion. There is a covering on the return pipe called armour flex. this armourflex stops ice migration inside the walls of the fridge. If it breaks away, the ice expands around the pipe and and pushes on the insulation foam which then cracks and makes those loud noises. Have heard this noise many times on a particular brand of fridge to a point where some customers have dived for the floor thinking they are being shot at. Repairing that problem is a biggish repair and not cheap. You will find if it is the compressor it normally only happens at either start up or switch off (a clattering sound)
3helpful
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
1helpful
Intermittent flapping noise whirlpool fridge freezer
Hi: Go easy on my rating as this is just something to try. You say it dosn't have a dispenser. Does it have an Ice maker? If so is it hooked up? If not try raising the lever on the ice maker up to the off position. The water valve may ve trying to open and without water pressure it will make a noise. It would also be related to the switches on the door. I hope this helps, Jeff
Ice maker is making a creeking noise
I went in and knocked all the ice out and it started to work just fine.
2answers
Icemaker noise and malfunction
on the back wall just above or under the fill tube youl find the wire harness , simply unplug the ice maker, while your at it 3 1/4 screws mount the ice maker to the side wall, youll have more room in freezer by removing it
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
