Question about Nokia 5130 Cellular Phone
5130-C2 KEYPAD NOT WORKING
I HAVE A NOKIA 5130 C2 PHONE. HERE THERE IS A COMPLAINT IS THAT KEYPADS ARE NOT WORKING PROPERLY IN MY PHONE. SOME TIMES EVEN I COULDN'T ABLE TO DIAL THE NUMBER, AND SOME OTHER TIMES I AM UNABLE TO GET THE CONTACT LIST.
KINDLY TELL ME THE SOLUTION.
  • 3 Answers
100% solve problem
Posted on Oct 05, 2009
    New Friend:
I have a nokia 5130 xm , now its keypad is not working
Posted on Sep 12, 2010
    New Friend:
Hi my nokia 5130 power key is not working what i am do
Posted on Dec 22, 2009
  • koushik dutta Sep 03, 2010
    hay dear change the keypad ic
    New Friend:
5310c keypad 456notworking which ic remove
Posted on Dec 06, 2010
    New Friend:
Is there is any way to make keypad working without is by using jumper for nokia 5130
thanks
Posted on Mar 17, 2010
    New Friend:
Tolong saya bos.5310 saya tombolnya gak fungsi.saya mau jamper aja ke2 ic nya.masalahnya blower saya lagi gak bagus tolong ya........trim,s
Posted on Mar 25, 2010
    New Friend:
Keypad not working
Posted on Feb 16, 2011
    New Friend:
Change power ic
Posted on Jan 26, 2010
    New Friend:
Dono ic chenze karne ke bad v koi keys kam nahi kar raha hai
Posted on Oct 18, 2012
6ya staff
SOURCE:
My nokia 5130's keypad is not working what can i do for thid one
Why you had given to Nokia Care, What was the problem which take you to repair center.you should explain first.Hy, Chandraka, first thing make sure if your device is charging, if charge that means your device is working there is problem with keypad belt (which you need to change), so second you should not take your device in prior condition then before with Nokia Care, i think you should give responsibilty of this to Nokia Care.
Jun 29, 2012 | Nokia 5130 XpressMusic Red Unlocked Import...
My nokia 5130c kepad is not properly working that the key is 6,9,# is not properly working
Thanks for writing Fixya. I am Marion and let me help you with this.
There are reasons why your phones keypad is not working, first, have you tried re aligning your keypad if it fits exactly on the button, also, you may try pressing the keys without the keypad tofind out if the problem is just on the keypad or on the phones hardware already. Also, the keypads functionality may affect if it had a water spill or had dropped previuosly.
Jun 24, 2011 | Nokia 5130 Cellular Phone
When i switch on the phone it only shows the nokia and remains blank white screen..so i want to flash my mobile (5130 xpress music).. so where can i download the flashing software??? please suggest me a...
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 04, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
How do i lock my keypad on my nokia 5130? Thanks
hello,you can kindlyb follow the shortcut procedure below,
press MENU>AND STAR BOTTON ON YOUR KEYPAD.BUT YOU HAVE TO MAKE SURE IMMEDIATELY YOU PRESS THE MENU BOTTON YOU CLICK ON THE X BOTTON ON THE BOTTOM LEFT OF YOUR MOBILE PHONE IN NOT LESS THAN 2 SECONDS.
THANKS FOR USING FIXYA.
TAKE CARE.
Apr 06, 2010 | Nokia 5130 Cellular Phone
Keypad
nokia 5130c keypad problem
Dec 12, 2009 | Nokia 5130 Cellular Phone
I HAVE A NOKIA 5130 C2 PHONE. HERE THERE IS A COMPLAINT IS THAT KEYPADS ARE NOT WORKING PROPERLY IN MY PHONE. SOME TIMES EVEN I COULDN'T ABLE TO DIAL THE NUMBER, AND SOME OTHER TIMES I AM UNABLE TO GET...
Hello. This is a common issue with keypads when the unit starts ageing. The flex cable needs replacement. Check the following and look up your model.
http://www.thefind.com/electronics/info-keypad-flex-cable
It is pretty straight forward to replace one the phone is dismantled.
Sep 07, 2009 | Nokia 5130 Cellular Phone
For knowing the keypad code
hi out your sim and memory card and then press (green button+3+*+red button) then your keypad code rest and 12345 work
Jun 18, 2009 | Nokia 5310 Cellular Phone
Set change problem
go to any of the nokia care service center for more help
May 25, 2009 | Nokia 5130 Cellular Phone
Nokia 5130 Cellular Phone Logo
16,966 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
