I have a 3LSC8255EQ0 side by side, once defrosted it appear to work ok.
after about a week or 2 the fridge stops cooling and the freezer follows. then ice can be seen forming on the white back panel of the freezer (this is now fridge temp.)if i defrost if for a day, it will work again as described above. and the cycle continues.
what can the problem be?
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
heatman101
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
