I have a Toshiba TDP-S20 projector that will not power up the lamp.
It initially has the standby lights illuminated, but when one tries to power the lamp up, there is not even a flicker, and it then flashes a red lamp light on the top panel - which suggests a fauly lamp.
Now the lamp is good (and so are the 4 spares I have) as I have put them all into another unit and they all power up. The colour wheel is spinning, and all board connections seem to be in order.
Is there a secondary power supply that kicks the lamp into action?
Thanks
Andy
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Please dont forget to vote this answer was helpful
Many thanks
1. Turn-off
the device by pressing the "ON/STANDBY" and unplug the power
cord
2. In the meantime, hold down buttons "ON/STANDBY",
"MENU" and "INPUT and plug-in the power cord
3. The lamp
operation counter will automatically turn to zero
4. Check if the
lettering "0H" appears on the lamp operation counter in the
status display
5. After the lamp operation counter has turned to
zero, turn off the projector by pressing "ON/STANDBY" and unplug
the device.
ok
the red light on it just flashes and it will not power up and click on...
I have the same problem projector was working fine then when I tried to turn the power on (from stand by) green lights came on but no lamp light. After leaving it for about a minute the red lamp light came on. What can I do that won't cost a small fortune.
